Blackberry Music Gateway
Old Jun 2, 2012 | 02:16 PM
cheech's Avatar
Default Blackberry Music Gateway
Im trying to get my iPhone to play music in my stereo, but im left with only a few options because i dont have a 3.5 jack or any rca aux input in car.. but i came across this blackberry music gateway and i am wondering if this would work... so if anyone knows would this work on a 2007 outlander's Bluetooth connection? or am i stuck with a hard wire option which is pulling out the radio and connect it threw the aux inputs?
Old Jun 2, 2012 | 03:53 PM
Claude_A's Avatar
The wire should be in the center console. Open the back by gently pulling it off (It's held by snap plugs).
The connector is called C-117.
Run the connector of your choice from C-117 to where you wish.
6 is RH +
4 is LH +
5 is common ground
see attached snips for location and wires id in the connector.
Attached Thumbnails Blackberry Music Gateway-auxwire.jpg   Blackberry Music Gateway-c117.jpg
Old Jun 9, 2012 | 08:20 PM
FAUEE's Avatar
The BMG works great. Only downside is there's a slight noise from the LED in it. I will be hardwiring it and installing a speaker selector so that if we want to use the OEM inputs again over the weekend.
ash
Sep 2, 2007 05:32 AM
