Bluetooth does not call
Old Jan 11, 2012 | 11:59 AM
skipperx's Avatar
Default Bluetooth does not call
I am trying to set up the OEM bluetooth in my 2007. I managed to pair my phone. The handsfree system can receive incoming calls. But when I tried to call/dial out, it did not work. When I tried to dial by voice, it added a zero in front and started dialing. I did not want to go through the operator, so I canceled it. Then when I tried to dial by punching in from the MMCS console, it said dialing but no dial tone on the car bluetooth or phone and then timed out. On the console, it showed the bluetooth and phone signal bars OK.
The phone is a Nokia 5800. It worked on my old car. Is there something I have to set on the car side to allow calling?
Thank you.
Old Jan 12, 2012 | 08:09 AM
milliesdad's Avatar
On my 2011 Outlander, all I had to do was to pair the ohone to the car and make sure that the phone is set to bluetooth.
One time I did have to turn off the phone, pull battery and then repower the phone.
Has worked great since then
Old Jan 13, 2012 | 10:19 PM
skipperx's Avatar
Well, I tried taking the battery out of the phone and repowering. Did work either. It's odd.
Old Jan 15, 2012 | 01:16 AM
hemdd's Avatar
I had the same problem. This is probably caused by old firmware on the 5800. Try to upgrade your firmware.
Old Jan 15, 2012 | 08:15 PM
cerps's Avatar
Just had this same problem on my ' 08 today. I can receive, but can't call out from the phone. I'm on a motorola Atrix so firmware shouldn't be a problem.
Old Jan 15, 2012 | 09:23 PM
skipperx's Avatar
Thanks, hemdd. I just updated the phone software and it workes fine now.
RussianDSM
Oct 26, 2006 02:10 AM
signtist2004
Jun 4, 2006 03:18 PM
mysterio2099
May 16, 2006 08:25 PM
Trader4Less
Apr 21, 2005 01:03 PM
zaskar888
Oct 5, 2004 11:10 AM
