Bluetooth Questions....Frustrated!
Old Mar 24, 2014 | 05:28 PM
Tyler.M's Avatar
Well in front of the dome lights towards the windshield there is a perforated chunk ill just have to get some pics up i guess
Old Mar 25, 2014 | 10:39 AM
ktmkirby's Avatar
That's where the mic sits.....small black box. Pull the dome light plastics off and see if it's there. If it's not, then likely the bluetooth module isn't either, which is located behind the radio.
Old Mar 25, 2014 | 02:50 PM
Vadimus's Avatar
If USB is working BT should be as well.
Old Mar 25, 2014 | 04:32 PM
Tyler.M's Avatar
Opened it up and this is what was inside is the black box there the mic?
Old Mar 25, 2014 | 06:31 PM
ktmkirby's Avatar
Kinda dark, but it should be plugged into the white connector. I only say check here because when if you have to get a BT module, it comes as a kit with the mic. I just had to do this in February. My 09 ES Outi came prewired with buttons on steering wheel but no BT module. I ordered it and installed it myself.
Old Mar 25, 2014 | 07:28 PM
Tyler.M's Avatar
Yeah the white connector is plugged into that black "mic" well thats good ill bring it to the dealership have them look into it
Old Mar 25, 2014 | 09:03 PM
boogunoogun's Avatar
look for the bluetooth module below the radio
Old Mar 26, 2014 | 04:34 AM
Tyler.M's Avatar
Do I have to pull the radio out to get at it?
Old Mar 26, 2014 | 01:13 PM
milliesdad's Avatar
Yes.
the grilles on each side of the radio come off, then the radio is screwed into the framework.
When you depress the "talk" button do you get anyboddy saying anything?
Perhaps BT module bit the dust.
Old Mar 26, 2014 | 01:16 PM
Outlaander's Avatar
Look at the following thread for a photo of the module from underneath and, later on, instructions on how to get at the module.
https://mitsubishiforum.com/forum/mi...h-issue-45574/
