Buzzing from tweeters.....
Old Oct 25, 2005 | 04:46 AM
Jewelz's Avatar
Default Buzzing from tweeters.....
I installed some tweets over the weekend and i get a annoying buzzing sound from the driver side tweeter. Its not happening on the passenger side. I tried switching the wires around and that didn't seem to help. I switched the tweeters thinking it might just be a faulty tweeter, but that didn't work either. Does anyone know whats happening and how to fix it?
Old Oct 25, 2005 | 11:59 AM
JMC's Avatar
JMC
Default RE: Buzzing from tweeters.....
Could it be the tweeter cover? Maybe it's not in right and yr getting some buzz from the plastic?
Just a thought....
Old Oct 25, 2005 | 01:13 PM
Jewelz's Avatar
No its not the covers, if it was, then the passenger side one (the one that wasn't buzzing) would not have buzzed when I switched it to the driver side. It has something to do with the wiring, cause it gets faster when I accelerate. Thanks tho. Any other thoughts?
Old Oct 25, 2005 | 01:36 PM
drh's Avatar
drh
I could be wrong, but it almost sounds like something is grounded or not grounded correctly.. maybe a wire is bare or somthing
Old Oct 25, 2005 | 01:48 PM
outlancer's Avatar
have you switched the antenna out, if so try putting the stock one on. If not check your plug wires for cracks cuz i know some times the wires cause interference with the radio
Old Oct 25, 2005 | 04:55 PM
Punisher's Avatar
if that fails, try switching the passenger out to the driver.
Old Oct 25, 2005 | 09:03 PM
Jewelz's Avatar
I still have the stock antenna on the outside of the car. As for the cracks in the plug wires, I thought our outties had direct ignition?
ORIGINAL: outlancer
Old Oct 26, 2005 | 01:19 PM
JMC's Avatar
JMC
It sounds like it might have something to do with the wiring if the buzzing gets faster as you drive. ..and it's only coming from that one spot eh?
Old Oct 28, 2005 | 05:03 PM
wicked_outlander's Avatar
check your wiring installation, sounds like a grounding wires.
eloylb
Mar 9, 2015 09:29 PM
eloylb
Mar 9, 2015 09:18 PM
98Eclipse2G
Mar 18, 2011 09:28 AM
aswahdan
Nov 12, 2004 10:25 AM
moleman
Sep 17, 2004 01:48 AM
