A/C Noise while on lowest setting
Old Sep 2, 2007 | 03:26 PM
BoldlyGoingNowhere's Avatar
Default RE: A/C Noise while on lowest setting
The recirculating mode is separate thanmax AC at least it is if you have the manual AC in the LS.
Max ac = temp **** all the way to the left, the light in the middle of that **** will turn on and the engine fan will cycle quicly and stay on a long time.
Not Max ac = 1 click to the right on the temp ****, I think the recirculate light goes out, the fan settles down but still cycles occasionally
Recirculate mode without max AC = stay at 1 click to right off max AC then poke the middle of the temp **** and the recicurlate light will come on. The enginefan cycles similar to Not Max ac.
In the models with the automatic temp **** I dont know how it works vs the engine fan speed.
It seems Max ac cycles the engine fan to cool the AC condensor more when the vehicle isnt in motion or moving slowly.
Old Sep 3, 2007 | 04:59 PM
puddy's Avatar
if its the same as my warroir trim push the centre of the dial in and hold for ten seconds repeat to turn on and off.
All 3 circular dial have a push in button to adjust things
Hope this helps?
puddy
Old Sep 7, 2007 | 08:35 PM
tufduck's Avatar
ok after a few observations on my ac, it seems that everytime the fan kicks on, it is loud as hell. Does all your outties A/C fan sound that loud when max ac?
Old Sep 7, 2007 | 09:38 PM
If it sounds like an airplane then thats about right
Old Sep 8, 2007 | 12:18 AM
tufduck's Avatar
ya it sounds like a turbine fan from a jet engine..lol
so bold, your ac is loud also?
Old Sep 8, 2007 | 11:00 AM
Its not the AC its the engine cooling fan. It runs to cool the condensor faster when the car is idle or in slow traffic. It is a good thing, many of my older cars would blow warm air in heavy traffic until the engine got hot enough to turn on the fan.
As far as the fan being loud, it is quite loud, for what its worth I was next to a Jag that was just as loud theac ran the same way.
Don't worry about it it.
Old Sep 8, 2007 | 01:00 PM
tufduck's Avatar
cool. well my '95 avalon even when max ac, the fan never turns on. It turned on after a while it it was super quite. I don't know about the new cars this generation but ya.
redturboeclipse
Mar 15, 2012 12:00 AM
perla
Sep 1, 2008 10:41 PM
Camel3g GT
May 24, 2007 12:32 PM
biscuit
Feb 22, 2007 04:55 PM
