Central locking issue
Old Apr 22, 2019 | 07:54 AM
Outjuro's Avatar
Default Central locking issue
Im having issues with the central locking on my 2008 outlander (non keyless entry), upon pressing the unlock or lock button on the key the hazard lights flash however there is no response from the locking mechanism. The fuse for the locking was blown and once replaced with a new one it blew right away, I tried disconnecting each door lock however its not them. Does any one have any ideas on what is causing this issue?
Old Apr 30, 2019 | 11:20 AM
binzd's Avatar
you have a short to ground on any one of the wires involved in your lighting - DO NOT attempt to jumper the fuse or you will fry your BCM - disconnect one harness at a time and check to see if it blows a fuse, and the replace the fuse and move to the next connector, it's a pain but after a couple dozen fuses, you will find the short (or use a test light if you know how to set it up) Goo d Luck
Old Apr 30, 2019 | 11:40 AM
Outjuro's Avatar
Thanks for that, will be a tiresome job but hope to find the issue, by lighting do you mean the wiring to the actual headlights etc?
Old May 1, 2019 | 12:59 PM
binzd's Avatar
kiwimitsi
Oct 29, 2015 04:43 PM
JimBob
Feb 12, 2008 12:07 PM
blackspeed
Aug 29, 2007 10:28 AM
blackspeed
Aug 29, 2007 10:25 AM
ace
May 12, 2006 05:55 AM
