Cigarette lighter not working
Old May 27, 2012 | 04:11 PM
jthorn75's Avatar
Default Cigarette lighter not working
Had anyone else had thier cigarette lighter not work... I've had to use the one in the center console... Anyone know how to fix this
Old May 27, 2012 | 05:06 PM
Claude_A's Avatar
Front console and rear cargo are on only when the engine is running.
Center console is on all the time.
If one is not working per the above check your user manual as there is at least two fuses for them in the left lower portion of the dash, behind the flip tray. One for each of the above.
Old May 27, 2012 | 05:34 PM
jthorn75's Avatar
That's a start ill check it out
Old May 27, 2012 | 07:08 PM
jthorn75's Avatar
Good to go Lol thanks
Old Mar 4, 2017 | 06:26 PM
PC Mech's Avatar
Having the same issue, the wire might be broken, will try and open it to check
Old Mar 4, 2017 | 07:47 PM
Sic_Lucky's Avatar
If the fuses are good then its the socket that's bad. There are circular wires behind the socket that act as a fuse and breaks. Either you replace the whole lighter socket or just bridge the wires by squeezing them together with a pliers. I've had to do this with 2 previous mitsubishis.
Old Apr 13, 2017 | 11:43 PM
deadguy's Avatar
Check fuse #19. Mine didn't work and after replace fuse #19 it works again.
mahicks3322
Nov 3, 2021 01:14 AM
McNeil
Jun 22, 2009 05:01 PM
Maverick07eclipse
Dec 13, 2007 07:44 AM
BrunoBoy650
Feb 14, 2007 03:31 PM
3000GTSL
Jul 27, 2004 10:42 PM
