Clock spring ribbon.
Old Apr 2, 2013 | 07:00 AM
activeviii's Avatar
Default Clock spring ribbon.
Hi All,
In need of a little advice.
SRS light was on so i went for a little investigating. this is what i found.
This is the damage to the ribbon cable on the clock spring.
Local dealer wants half a pint of blood ontop foe 3 limbs and a lung.
Any one knows where i can get new ribbon, what its called or can i put a solder blob on it.
thanks for any advice you can offer guys.
Im in the UK so its a little hard to get information
All the best.
Phil.
Old Apr 2, 2013 | 08:23 AM
ccernst's Avatar
I think before you try solder, I'd try rear windshield repair..stuff...it is like a conductive epoxy. I'd worry that the heat from the solder would damage the ribbon further.
Old Apr 2, 2013 | 08:27 AM
activeviii's Avatar
the damage is right in the middle of the ribbon, right where it sits on the roller so i think it will wear out to quick. great thought though.
i have just run a continuity test and 3 out of 5 are damaged. only 3 are used out of the 5 so a bit of a bummer.
for now im going to resemble so i have the horn working and then try and find a recon part.
Old Apr 2, 2013 | 11:27 AM
tcp's Avatar
tcp
Default There are similar cables available
Please check this out:
Cable Assemblies | Flat Flex, Ribbon Jumper Cables | DigiKey
you may be able to measure the pitch of the cable and, if it has removable ends, replace with something similar.
Old Apr 2, 2013 | 11:32 AM
activeviii's Avatar
Great find, just a shame there is nothing long enough. It needs to be around 30"
All the best
Phil
Old Apr 2, 2013 | 02:47 PM
ivanz's Avatar
The ribbon is part of the clock spring. It is part number 8619A018 I believe. You can Google it for an image to compare to make sure (or ask the dealer). I think you can get it for $60 on eBay (but it says 2010+ Outlander for some reason, but I think all current Mitsu cars use this).
See here:
8619A018 - Relay,flasher & sensor for Mitsubishi Outlander XLXYZ5 - Auto parts (see very top, repair manual part # is 82643)
Old Apr 2, 2013 | 02:55 PM
activeviii's Avatar
See here:
Thanks for that.
Turns out its the lancer one as well. Only one on ebay. $129
Old Apr 2, 2013 | 03:46 PM
ccernst's Avatar
probably not many junkyards with newer mitsus...
Old Apr 2, 2013 | 10:44 PM
ivanz's Avatar
Originally Posted by activeviii
Thanks for that.
I found a replacement one called "CSP151 Clock Spring" for $50 which claims to work as well. The clock spring, like the majority of Mitsubishi parts, are shared between many cars. So there is probably quite a few choices out there. Again, just double check before buying.
Old Apr 3, 2013 | 06:01 AM
activeviii's Avatar
thanks for all the replies
i have not one outie in any of the scrap yards within 300 miles
i have a Dismantlers close by so im going to see what they have.
i will also look into that part number thanks Ivanz
all best
Phil
