Clutch and flywheel replacement
Old Jul 22, 2020 | 09:29 AM
jimmyrinse's Avatar
Default Clutch and flywheel replacement
I am tempted to do the job myself as I've been quoted around £1k to have it done. Never delved into this area before, done brakes, suspension, drive shafts etc etc but never took parts of the engine apart.
I have a 2007 outlander with the BSY engine have been looking at the workshop manual but it isnt very helpful on how to get it all apart. Is there a guide floating around somewhere which would make the job easier that anyone knows of?
From what i can ascertain i need to remove the n/s section of the engine which seperates just past the flywheel?
In which case I'd need to remove the entire n/s strut, wishbone, driveshaft etc to gain access, battery and most stuff directly above. Then would it be a case of just undoing all the bolts and off it comes exposing the clutch and flywheel?
Any advice and/or help would be much appreciated
Old Jul 22, 2020 | 12:22 PM
jimmyrinse's Avatar
ok so it appears its not on the n/s its more central and sits just to the left of the starter
Old Jul 26, 2020 | 01:32 PM
jimmyrinse's Avatar
Default Thanks
Cant believe in 13 years no one has ever done this themselves. Nm I'll figure it out.
sk8dudety
Nov 12, 2007 10:37 AM
97spydergs
Oct 29, 2007 02:14 PM
jerusry
Oct 14, 2006 12:35 PM
gstgurly22
May 12, 2006 09:16 PM
95HGeclipse
Mar 29, 2006 08:16 PM
