code p1751
Old Jul 1, 2014 | 09:18 AM
Liam McClurg's Avatar
Default code p1751
hello everyone i am new here so hopefully im posting in right spot! Alright so we have a 2003 outlander here at the shop.came in not running,had new timing belt put on,than cyl miss fixed that. than had to check for inspection founf that reverse lights werent coming on.so thought bulbs were bad.not the case,than we thought fuses and relays,but there all good.so we next tried the neutral switch that didnt fix it.so we replaced the ecu.that still dosent fix it. ran scan tool found out code p1751 a/t control relay fault. tried activating the solenoids wouldnt let me.just kept sating retry or exit.so does anybody know what the cause could be? also in fail-safe mode in 3rd gear and neutral light flashes.Thank you! Liam
Old Jul 3, 2014 | 07:09 AM
can someone please help me out on this.help would really be apprecitated!
Old Jul 4, 2014 | 04:58 PM
mdbullet223's Avatar
Did you actually replace the relay? everything I find online says once replace should work fine. If you did replace it and it blew again then I would think somewhere it may be grounding out.
Old Jul 7, 2014 | 09:39 AM
well we have been switching relays around in the fuse box,because there all the same.But still dosent work.we did jump i think its 3 and 4 and lights came on and worked,but the nutrel light still flashed and was still in third gear sport mode.
Old Jul 7, 2014 | 09:46 AM
from the a/t cirut wiring diagram. 4 and 3 have power. 2 and 1 have 0 power.
jmannc79
Mar 27, 2015 03:34 AM
MonSport
Feb 21, 2004 05:59 PM
bigbubbles07
Dec 15, 2003 12:33 PM
Alex
Jul 10, 2003 02:47 PM
