Common Problems?
Old Oct 13, 2011 | 09:52 PM
mojo0107's Avatar
Thanks NDJ. I went to pick it up today and well it needs an allignment after the steering column put back in. Everything fixed...windows, etc... but now when the Wheel is straight the car turns right...SO I left it there Tech gone already I'll call in the am. I know it turnes out the be a cable from the shifter to the steering column that was binding upfor some reason and locked thing into place.
Old Oct 13, 2011 | 10:39 PM
ivanz's Avatar
Alignment after putting in a steering column
Replacing a steering column should not affect alignment. Something sounds really fishy...
Old Oct 13, 2011 | 10:55 PM
MTWallet's Avatar
Steering wheel is probably just not "centered" with the front wheels. I had that happen once with my Montero Sport, I don't what they changed to fix it but it was a quick fix.
Old Oct 14, 2011 | 10:13 AM
ndj's Avatar
ndj
Two likely options depending on the detailed symptoms (i.e, if the cars pulls to one side when been steered straight, or, simply centring the steering wheel turns the car)....
1. What was quoted above. The fix is to remove the airbag, unbold the steering wheel, align, re-assemble.
2. The front wheels weren't centred when the new column was installed. Not sure if that's possible in modern cars; I'd guess Mitsubishi would make it idiot proof, but lots of them about.
Both are rookie mistakes but neither a problem to fix.
Old Oct 14, 2011 | 07:04 PM
mojo0107's Avatar
Wasn't an allignment issue. He had to pull the wheel and move it one notch to the right. It's fine now and our new car is home...Thanks for all your help. Now for setting up the hands free phone.
DANISH DELUXE
Feb 6, 2009 09:42 AM
wa98146
11
Dec 7, 2008 10:19 AM
bonzey01
Jan 31, 2007 03:01 PM
teufelhunde
Jul 18, 2006 01:36 AM
wojeepster
Jul 7, 2006 04:29 PM
