Considering an outlander
Old May 14, 2020 | 07:26 PM
Isoldmysaturn's Avatar
Default Considering an outlander
Hello, we're considering a 2019 outlander se 2.4 awd. We would use it as the wife's daily, the occasional road trip, as long as it gets the advertised 29MPG, towing 3000-3500LBS around town often, and towing a 2400LB boat out of town a couple times a year. How would this vehicle do for this? How reliable are these outlanders?
Old May 15, 2020 | 03:45 PM
sock puppet's Avatar
The 2.4 Outlander doesn't fit your intended usage as it is rated to tow only 1500 lbs. per the US owners manual. The GT with the V6 is rated to tow higher. I tow my 1500 lb. aluminum boat with mine and it does fine. For 3500 lbs. I would want a larger vehicle for stability (I'm not an amateur in this as I own 6 trailers and have an F350 for serious work).
Old May 16, 2020 | 05:48 AM
that sucks. I miss the day when every vehicle had a tow rating, and SUVs like the outlander could all tow at least 3000LBS. after having driven an RVR, I could easily see the 2.4L outlander pulling 2000-2500LBS. Oh well, on to other vehicles. Thank you.
Old May 16, 2020 | 07:50 AM
SERPENTOR's Avatar
2020 Mitsubishi Outlander GT/Towing capacity
3,500 lbs
V6 can do it.
Old May 16, 2020 | 08:00 AM
There aren't any used v6s in my area
Old May 16, 2020 | 02:02 PM
Extremero's Avatar
https://www.mitsubishicars.com/outla...owing-capacity
https://www.carsguide.com.au/mitsubi...-capacity/2019
The diesels are rated ~4500lbs, the rest ~3500lbs.
The 1500 lbs was probably the spec for unbraked trailers.
caskey_b
Oct 7, 2015 03:01 PM
Infinitrium
Nov 22, 2014 11:32 PM
Michael King
May 8, 2013 11:07 PM
jms
Sep 14, 2012 05:14 PM
TM22
Sep 15, 2011 04:32 AM
