Crusher washer for oil pan plug
Old Mar 28, 2011 | 09:42 AM
newoutlanderfan's Avatar
Default Crusher washer for oil pan plug
So this is a stupid question, when you put the crusher washer on the plug, does it matter which way you put it on (one side is smooth, one has a groove in it). I think I am leaking oil and am wondering if the mechanic put it on the wrong way (or does it matter)
I would think the smooth side faces OUT (or UP) while the groove side makes contact with the plug
Thanks!
Old Mar 28, 2011 | 12:08 PM
Claude_A's Avatar
Per the manual torque 29 +- 3 ft-lb and instal per illustration.
Old Mar 28, 2011 | 04:26 PM
I do not think it makes a difference.
Old Mar 29, 2011 | 05:52 PM
ccernst's Avatar
shouldn't make a difference. you sure he put one on at all? I made the mistake once of not putting one on the first time I did it.
Old Apr 1, 2011 | 04:41 AM
hotponyshoes's Avatar
Or he just re-used the old one?
They are ment to be a once-only item.
If it has no cracks or splits in it you may get away with re-using but you normally need to torque it up tighter to stop it leaking then risk stripping the threads or getting the plug stuck.
Personally I would suggest using a flat copper washer, does not matter which way round it goes then but you do need both mating surfaces to be clean and un-damaged before fitting.
Old Apr 1, 2011 | 10:23 AM
ruski's Avatar
What's the size for our washer?
Old Apr 25, 2011 | 10:13 AM
No_Floaters's Avatar
For a 2007-2010 XLS; 6 Cyl, 3.0L it would be a 14mm. Ask for an M14.
ccernst
Jan 14, 2011 08:38 AM
Vadimus
Nov 26, 2010 12:13 PM
Printerman
Jan 14, 2008 02:23 PM
novetek
Mar 23, 2006 09:04 PM
modestmitsu
May 13, 2005 05:31 AM
