CVT Transmission problem
Old Aug 23, 2016 | 12:23 PM
  #21
Lancerguy2013's Avatar
Always use the correct Mitsubishi Fluid..pretty simple..even easier...do it at the Dealer...ask them what they use...If it's not Mitsu fluid...find one that does...
I've dealt with 4 Dealers here in the Toronto area..they all use the specified fluid from Mitsubishi. If they do the service..they have the records and if something goes wrong it's on them.
Best of Luck
Old Feb 18, 2017 | 01:19 AM
  #22
carlitoslam's Avatar
I have a 2009 outlander LS 2.4 CVT transmission. It started having CVT transmission issues after 130,000km ...it costs me $6000 to fixt it
CVT transmission is very weak and won't last compare to the normal automatic transmission.
Old Nov 22, 2023 | 01:59 PM
  #23
David Melton's Avatar
Default Same issue
Originally Posted by sonofabitchy
My 08 Outlander,2.4 cvt is doing the same thing. I noticed tranny issues after 1st fluid change.Problem is worst on cruise control.The rpm will jump up then back down causing a jerking sensation in the vechicle.I have noticed that when this problem happens in normal mode and I move shifter over to sport mode(cruise set), the problem goes away.Iam leaning towards a faulty module but have no info on all the tcm modules
​​​ I'm having the exact same issue of you find a solution please let me know
Old Apr 10, 2024 | 04:53 AM
  #24
Hodado's Avatar
You could have avoided your cvt problems by changing the fluid on a timely basis.Most people who have this issue neglect the maintenance.CVT's are not the same as conventional transmissions and The Jatco requires frequent fluid changes.Hopefully the newer models don't.
Outie_NZ
Jan 25, 2025 05:55 AM
niazqamar
Apr 27, 2022 08:22 AM
maurice
Jul 15, 2017 11:15 AM
letticeb01
Dec 15, 2013 08:32 AM
Erakiel
Jan 11, 2010 12:37 PM
