Dan Dekoker ,I need your help with the HID issue
Old Jun 1, 2009 | 11:11 PM
cbcctv's Avatar
Default Dan Dekoker ,I need your help with the HID issue
Dan I need your help!!!
I was using 25V 3300UF capacitor but instead of soldering it to the switch ,I soldered it to the organge color socket below.( take out the wires that connect to PIN 85/86 and solder the capacitor on them and put them back again)I tested it and worked good when I put the key on ignition,which DRL normally on. However,when I turn the headlights on ,the capacitor blowed up. my question is Do I need to solder the capacitor to the switch only ??? or Is my capacitor too small ? 3300uf I think is enough though.
Mine s 06 outlander SE and now I have to keep my headlights on all the time otherwise it won't light up.I don't know whats wrong with it but I don't want to keep my headlights on all the time.
I attached your picture below.
Attached Thumbnails Dan Dekoker ,I need your help with the HID issue-qq-.jpg
Old Jun 2, 2009 | 10:38 AM
tcp's Avatar
tcp
Default Unless it is non-polarized,
you need to make sure you have the positive and negative lead connected to the right points. Caps will blow up if you reverse the polarity.
Old Jun 2, 2009 | 12:55 PM
cbcctv's Avatar
Default I will try again
I will go pick some 25V 4700UF caps and do the exactly as instructed.
Thx for your advice TCP !
I will post the updates.
Driver99
Feb 25, 2008 02:16 AM
diggedy
Sep 14, 2007 04:00 PM
Patrick
Aug 23, 2006 06:20 PM
Patrick
Jun 1, 2006 09:05 PM
puffy
Jun 7, 2004 05:16 PM
