Day time running lights vs Fog lights
I need to know if daytime running lights are the same as fog lights?
I have a 07 XLS with every option ( just purchased used for my daughter) and i cant seem to get the headlamps and the fog lamps BOTH on at the same time. In the owners manual it shows a differernt light stalk than the one i have. Am i missing something here? please help.. |
Interesting.
DRL's are not the same as fog lights. You should NOT be running around with your fog lights on if there's no fog. You blind the crap out of everyone. |
Originally Posted by Jims M
(Post 271338)
fog lights
Also,they will turn off when you put high beams on.
And you can't use the fog lights when only your parking lights are on (the first setting on the headlight switch stalk). This may be what is confusing you. Try turning the headlight switch one more past the parking light setting.
(Post 271338)
@Jims M
to answer your question... the DRL on the XLS w/ HID lights are not the same as fogs..... the DRL uses 1156 bulbs and the fogs uses H11 bulbs.... read this thread.... https://mitsubishiforum.com/forum/sh...ad.php?t=25231 |
Originally Posted by bino
(Post 271411)
@Jims M
Thanks Dude, thats what i was looking for....
I followed the instructions and got further instructions for ramon. I didn't have the stalk with the fog light option and didn't want to mess around and put one in. So I gave this setup a try and am very happy with the way it turned out.:D
https://mitsubishiforum.com/forum/sh...t=lights+ramon |
