Direct battery power for gps tracker
Old Sep 20, 2015 | 07:11 AM
Roshid's Avatar
Default How to connect direct battery power for gps tracker
Hi I want to install a gps tracker direct power 12v from battery. Model outlander 2010 CW4W. Preffer front passanger fuse box near aircondition filter. Can anyone guide me which port or fuse have 12v positive always even switch is off?
Many thanks and appreciated.
Old Sep 23, 2015 | 11:10 AM
Guyfromhe's Avatar
I don't know which fuses are always on but it should be easy enough to check with a test light or a meter... Start by reading the fuse list for something that is active when the car is off, then test it, then wire into it (make sure to keep the fuse and fuse your new device). Make sure not to tie into something that is only on sometimes like dome lights or power windows... Power lock fuse might be a good place to start but you need to check the current draw and add in your device's draw to make sure you are nowhere near the fuse rating. Do not put in a bigger fuse under any circumstances!
If this is beyond your technical/equipment capabilities I would not attempt any electrical work on your own as you could wreck something.
Old Sep 28, 2015 | 06:44 AM
Roshid's Avatar
Many thanks Guyfromhe for the clue.
Old Oct 4, 2015 | 11:13 AM
jjrphs's Avatar
Once you find the correct circuit......this add-a-circuit kit makes it extremely easy to add your circuit without using a wire tap or cutting wires......
Amazon.com : PerformancePackage Direct Wire Radar Detector Fusebox Add a Circuit Kit - Mini Blade : Car Electronics Amazon.com : PerformancePackage Direct Wire Radar Detector Fusebox Add a Circuit Kit - Mini Blade : Car Electronics
Old Oct 11, 2015 | 08:05 PM
caskey_b's Avatar
Those Add-A-Circuit taps are very handy!!!
I used those when installing my heated leather seats in my Durango!!
AGAIN.. Keep in mind what Guyfromhe suggested about NOT going OVER the recommended draw
waid302
May 8, 2021 01:14 AM
oldskooldan
Jun 29, 2010 08:26 PM
jlh077464
Nov 15, 2007 11:14 AM
Jewelz
Oct 6, 2005 10:37 PM
