DRL to replace Fog kit?
Old Feb 3, 2008 | 10:39 PM
tufduck's Avatar
Default DRL to replace Fog kit?
Currently I have the HID on my outtie and the DRL. I see the outtie has a fog kit sold separate also.
But what if I get the Fog kit and replace the DRL by the dealer, do the fog light comes on with the HID?
I see some cars out there have their lights below the headlights on with their main headlights.
Is that possible for that fog kit to be on at the same time when my HID is activated?
Old Feb 4, 2008 | 01:55 PM
tdford's Avatar
Default RE: DRL to replace Fog kit?
ORIGINAL: tufduck
With HID and DRL, no.
Yes, great idea for Mitsu to not allow both to be on...[sm=boosign.gif] My dealer said that that the HID's are bright enough, so there is no point to having the DRL's on at the same time. Idiots. Most cars, HID, non-HID, DRL, non-DRL, doesnt matter, if they have fog lights they usually can be used simutanously with the low-beams. Which is what we want...
DRL's have been around for a while. But now more vehicles in the US are coming standard with them then before. Insurance companies say its a safety feature, I would agree.
Now, all the US models that have HID's come with DRL, which can not be operated like Fog's (no switch). But yes with most non-US models that have HID's do have the switch to control the "fog-lights". I just dont know if the "fog-lights" on those models are called DRL's or Fog's???
Your idea of replacing your DRL's with the Fog kit might work for it will give you a switch. But theres a good chance that the DRL's are wired differently than the standard Fog's. So wiring harness might have to be changed. What we need to figure out is just how to leave the DRL's on all the time... and then we would just have Fog's on all the time.
Old Feb 4, 2008 | 02:33 PM
abrcrombe's Avatar
If you find anything out, let us know. I think most people with the HID's would like to do this mod!!
Old Feb 4, 2008 | 04:29 PM
tufduck's Avatar
oh darn..I'll guess I have to go to dealer and ask again and I'll try to dig through and see what I can find.
Old Feb 4, 2008 | 06:22 PM
tufduck's Avatar
alright im tick..i just found out some user from cardomain.com had his HID lights and the DRL's on...
http://www.cardomain.com/ride/2549820
scroll down and you'll see..omg it looks so better with both on...
Old Feb 4, 2008 | 06:35 PM
tdford's Avatar
ORIGINAL: tufduck
He didnt have the luxury package from the factory though. He says he had the dealer install the nav and HID's. He even has a pic before the nav went in...
So his "fog-lights" are probably not DRL's, but actual Fog's. So he probably had the right wiring and the switch before he got the HID's installed. Kinda backwards of what we want to do...
Old Feb 6, 2008 | 11:21 PM
antlip's Avatar
Has anyone bought the fog light kit yet to replace their dlr? On ebay the kit says this. If someone buys the kit and tries to plug it in, the auction says its plug and play no cutting required, then you can tell me if it worked haha.
FOG LIGHT KIT, WITH SWITCH , RELAY AND INSTALLATION INSTRUCTIONS
100% GENUINE FACTORY MITSUBISHI PARTS
PART# MZ380376EX
Requires re-coding of ETACS, Comes with re-coding instructions. If recoding doe's not work see your local Mitsubishi Dealer for Re-coding Help.
Old Nov 18, 2008 | 05:19 PM
Melvin8078's Avatar
You can replace the DRL to your fog lights or high beams. The installer will need a DRL module/harness and a resistor. Just like your low beams it will always be on. DRL module/harnesscan be ordered with the HID kit.
I am currently in the process of buying one but still need more info on HID kits and the install.
Old Nov 19, 2008 | 02:33 PM
tdford's Avatar
ORIGINAL: Melvin8078
You dont understand Melvin.... if you have OEM HID, the fogs act as DRL's and areON all the time until you turn on your low beams, which are HID. We want the fogs to stay on when the low beams turn on. And no, we do not have a fog switch. Yes, they are wired differently, and yes this is a stupid concept.
Old Nov 19, 2008 | 04:34 PM
Melvin8078's Avatar
[/quote]
My bad...
