Old Aug 13, 2012 | 04:45 PM
  #1201
Evo><'s Avatar
The MMCS .sc file format is attached. To create a Sony ATRAC3+ 128kbps audio stream file you need to download a copy of Sony's Sonic Stage 4.3 (free) from here. To convert a file to the format; import into Sonic Stage and then from the track list view right click and select "Convert File Format"; in the pop-up select ATRAC3Plus, Bit rate 128kbps, and uncheck "Add copy protection"
If you attach the first 80 bytes of an existing .sc file to the data stream of a aa3 file created by Sonic Stage it will play on an MMCS, but you will have to replace an existing tracks file as the audio indexes cannot be altered yet.
Many many hours spent researching and decoding this so far, along with the audio index formats. Hopefully we can use this to create a MP3 synching technique at the least.
File Type: zip
Old Aug 13, 2012 | 04:58 PM
  #1202
Otaku's Avatar
Originally Posted by Evo><
Strange indeed; I also couldn't find anything on this SLJA index, so set about trying to understand it using hex view, inspired by Otaku and Brian360's earlier success with the loading.kwi
So far I think I have a pretty good grasp of what's going on in the files, but as mentioned they have custom checksum which is stopping me altering them for testing.
This what I have decoded so far, see attachment.
Looks good, from what I can see..
Can you attach a couple of sample files ?
Old Aug 14, 2012 | 11:36 AM
  #1203
Evo><'s Avatar
Attached a extract from my unit but reduced to just the data from groups 00 0A 0B to keep the file size under the forums tiny file size limits, but should be enough to get a feel.
File Type: zip
Old Aug 17, 2012 | 01:38 PM
  #1204
BesSseN's Avatar
Hi please help me to hack the DVD Outlander 2008 - version is 261EM 1.09 APP 00.41.02, MAP Data M190 AEU_07_201001B Thanks !!!
Old Aug 17, 2012 | 03:25 PM
  #1205
Otaku's Avatar
NavHack!
Upgrade to 00006005.
Old Aug 18, 2012 | 07:40 AM
  #1206
jbitzer's Avatar
Originally Posted by Otaku
NavHack!
I'm sorry to be an idiot Otaku, but I have the 60.99 I believe software, will the NR261UM 00007004 version be all I need? Do I just burn to disk and put it in the system?
Old Aug 18, 2012 | 09:04 AM
  #1207
Otaku's Avatar
You need to extract the disk image from the rar file, and then burn the image to a cd..
Just make sure you pick the right region (EM/UM etc ), and download the latest version for that.
Old Aug 18, 2012 | 12:42 PM
  #1208
jbitzer's Avatar
I have the 261UM 1.09 ver 00.60.09, So the NR261UM 00007004 is the correct file? Will it also update anything else?
Old Aug 18, 2012 | 01:52 PM
  #1209
Otaku's Avatar
yes, 7004..
and no, its just the unit firmware..
Old Aug 19, 2012 | 11:56 AM
  #1210
Evo><'s Avatar
Any luck finding the checksum algorithm yet Otaku?
