Old Aug 20, 2008 | 04:24 PM
  #391
brian360's Avatar
Default RE: DVD in motion patch for NR261UM
Weird... has anybody else run into this issue? The versions are identical to mine (except the Navi & Audio microcomputer versions, but I don't know how that'd affect region coding).
There is a link to the original (unhacked) 00.30.94 image if you want to try reverting back.
Old Aug 20, 2008 | 04:32 PM
  #392
babingha's Avatar
Brian if you have that link I would like to at least have it just in case. Did you do the hack and did it work ok for you? Thanks!!!!
Old Aug 20, 2008 | 04:36 PM
  #393
brian360's Avatar
The link is on the same website you got the original patch from (which you even posted earlier). Look for 00.30.94, original version.
Yes, I'm running the same patch. I, along with otaku and rcostin, were the original people involved in creating the patch to begin with
Old Aug 20, 2008 | 04:38 PM
  #394
babingha's Avatar
Are all you guys in the US ? Also I did notice that when I did hack it would upgrade and keep re-prompting me to do it again. I did it twice then said no on the third time and ejected the disk.
Old Aug 20, 2008 | 04:46 PM
  #395
brian360's Avatar
Yes, I'm in the US. 08 Lancer GTS. As far as we know, all the "US" models use the "UM" version of the software.
Yeah, in order to "trick" the unit to accepting the update, the update disc has the version faked (bumped one up, i.e. 00.30.95 instead of 00.30.94). This makes it think when it reboots that there's another update ready. But you really only need to do the update once, then just eject the disc.
You might contact your dealer to see if they have an update disc with a version newer than 00.30.94. NOT the map upgrade, just the software version (should be free). If they do have a newer version, copy the disc for us, and we can make a patch for dvd-in-motion for it
Old Aug 20, 2008 | 06:43 PM
  #396
babingha's Avatar
I will check with the dealer and try and get the updated software and get you a copy!!
Old Aug 20, 2008 | 07:36 PM
  #397
diddy_X's Avatar
Brian360 please help... there are like 7 different links for downlaod...Which is the right one for my evo x. do i open or save the file...rookie question i know..
Old Aug 20, 2008 | 08:04 PM
  #398
diddy_X's Avatar
nevermind!!! i figured it out.. so simple.... good looks to the 3 of you guys!!! if your ever in South Fla. hit me up i'll buy u guys a round!
Old Aug 20, 2008 | 09:37 PM
  #399
BellaCroix's Avatar
ORIGINAL: brian360
So if I understand correctly... the existing patches will not work on a unit using:
BLD-NR-261UM 1.09 / 00.30.97?
About to take my car to the dealership in the next few weeks... I'll check for a software upgrade CD... any idea of a part number to request?
If I pull the drive and mirror/ghost it (not that I have that software available - or the adapter for that matter) would that work also?
Old Aug 20, 2008 | 10:14 PM
  #400
babingha's Avatar
OK I am an idiot. It appears that the original DVD I tried did not work but after turning of the car and trying another DVD later everything is working again. Thanks for all your help brian!
