Old Jul 31, 2008 | 02:49 PM
  #371
brian360's Avatar
Default RE: DVD in motion patch for NR261UM
If your version indication is the same as the version on rcostin's download page, I'd say it should work. But the risks are completely up to you to take. If the same thing happens to you that happened to Jaysmall, then you will have to pull the hard drive to fix it.
To minimize the risk of a problem, check the integrity of the ISO you download and verify it with the actual image you burn to a disc before inserting it in the MMCS. A corrupted download or an incomplete burn is most likely what happened to Jaysmall.
Old Aug 2, 2008 | 06:57 PM
  #372
ddawg1130's Avatar
I tried to install this. I inserted the cd and it popped up the screen asking if i wanted to do the install. So i clicked yes. i was thne brought to another screen that said:
Version up key is checked. Insert the version up key into the [KEY] slot inside the monito panel. Selecting [NEXT] will write the authentication code in the version up key and the key will become available only with this system.
with these options:
"NEXT" "BACK"
if i hit next i get this message:
Version up key which came with the map disk cannot be detected. Check if the key is inserted correctly.
and i cannot install the patch. Any ideas?
Old Aug 3, 2008 | 05:29 PM
  #373
llckll's Avatar
Has anyone successfully installed it on the version below?
I have application 00.30.97.
Old Aug 6, 2008 | 04:47 AM
  #374
dsoquendo's Avatar
Is there any word on the AUX fix? As in removing the block on the AUX video in while vehicle is moving?
Old Aug 6, 2008 | 08:59 PM
  #375
hadeswolf's Avatar
Still doesn't work for me T.T I have version .94 Tried at least 30 times, burned over 30 cd's most with different programs. Dam I just have bad luck.
Old Aug 7, 2008 | 10:47 PM
  #376
BellaCroix's Avatar
Okay... before I start downloading, burning ISOs, installing software... end up voiding a warranty and killing my system:
I have:
Loader: BLD-NR-261UM 1.09
Application: 00.30.97
On: 2009 Lancer GTS (Hi Outlander peeps)
I see a update for NR261-UM v1.09 on the site but it does not specify the App version. Will this work on my unit?
Old Aug 9, 2008 | 04:08 PM
  #377
taug6's Avatar
I have the same version with edgley (UK evo X with 2 little talibans thirsty for video movies). In order to avoid the Taliban's wrath,
I'll put a reward on a patch that will enable them to watch DVD's on the move
loader: BLD-NR-261EM 1.90
APP: 00.31.06
Seriously !!!
Old Aug 10, 2008 | 11:25 PM
  #378
hadeswolf's Avatar
Finally after countless attempts and countless downloads, finally got it to work. Friend finally burned it with nero for me. I've used over 15 programs but not nerom I've told him to burn it for me a month ago, but he kept putting it off. So a word of advice for anyone who can't get it to work, burn the iso with nero.
Old Aug 13, 2008 | 10:28 AM
  #379
Gotcha's Avatar
Any wordon version 00.30.97 patch yet?
Old Aug 16, 2008 | 10:52 AM
  #380
llckll's Avatar
ORIGINAL: hadeswolf
what application mumber is your unit?
