ECU/ABS fault C121D brake fluid preassure sensor (Outlander 08). How to fix?
Old Aug 16, 2016 | 12:05 PM
ProsjekX's Avatar
Default ECU/ABS fault C121D brake fluid preassure sensor (Outlander 08). How to fix?
So, got this fault which seems to be fairly common... ASC fault light in the display. I see there are several companies that offer repair service for this fault, but still fairly expensive. So does anyone know exactly what the fault or failing component is? I'm an electronics designer by profession and would prefer to try to fix it myself.
Had a failing ABS unit on my Audi A6 as well, and there I had to re-solder a broken bonding wire to the ceramic substrate... that was interesting with not the best equipment currently at hand when required.
Anyway, tips regarding this would be greatly appreciated!
newoutlanderfan
May 27, 2013 10:47 AM
bassactuator
Sep 8, 2008 09:05 PM
fallingapart3000gt
May 13, 2006 01:35 PM
j22ame
Aug 21, 2005 05:54 PM
3000gtyeah
Aug 17, 2005 08:22 PM
