Electronic brake reset for pad replacement
Hi all I have a 2018 outlander and I need to replace rear pads and rotors. I have an electronic e-brake so I need to retract caliper prior to starting. I have seen the manual procedures on you tube, but mine has a push start (no key) so the procedure doesn’t match. Is there a manual procedure to put it into maint mode with push start?
redturboeclipse
01-26-2011 07:10 PM
