tire size change vs speedometer
Old Oct 23, 2022 | 09:10 AM
murphy67's Avatar
Default tire size change vs speedometer
Is there a way to correct the speedometer for a change of tires? I went to a smaller diameter overall and am off about 5 percent.
Old Apr 29, 2024 | 02:56 AM
Metlhavens's Avatar
One way to correct it is by getting a speedometer recalibration tool or tuner. These devices can adjust the speedometer settings to account for the new tire size so that it reads accurately.
Another option is talking to a mechanic or dealership. They may be able to reprogram your vehicle's computer to adjust for the new tire size.
If you're looking for a DIY solution, you can also calculate the difference in tire diameter between your old and new tires and adjust your speedometer readings accordingly. Using the ruler at https://ruler.onl/ could help you get those measurements faster.
velv
Oct 16, 2017 09:29 AM
kannyrocks
Mar 11, 2016 08:27 AM
tweeder
Sep 2, 2015 08:22 AM
josh_raben1971
Jun 19, 2007 10:42 AM
unknownentity
Mar 3, 2007 08:18 AM
