Error code 1320 Mitsubishi Outlander LS
Old Apr 3, 2020 | 11:16 AM
Jacqua's Avatar
Default Error code 1320 Mitsubishi Outlander LS
Hello,
I have error code 1320 diagnosed for the Check engine light that is a continous burn for my 2008 Outlander - its a opened-end code does anyone
know where to start to fix this.
*checked the gas cap
*filled all of the tires
light is still on
Old Apr 3, 2020 | 03:52 PM
AWCAWD's Avatar
The service manual does not list this code specifically but Google is your friend when you need to start somewhere.
Auto codes
Interestingly enough, if one looks up the errors suggested by the above article:
1. Engine coolant temperature DTC codes would be (P0116, P0117 and P0118)
2. Engine Control Module (ECM) codes would be: 23, U0100,
3. Thermostat failure.
You can start with these but you may want to download the service manual first from this forum and also use a more sophisticated code reader. I suspect the current code was obtained with a generic one. The service manual is a great resource for diagnosis and fix. Good luck.
Old Apr 3, 2020 | 05:17 PM
Jacqua's Avatar
Thxs for the reply AWCAWD
I will start with the service manuel
Warborg
Apr 16, 2019 12:50 PM
Jarrod Wally Moreton
Other Mitsubishi Models
Apr 1, 2019 03:17 AM
chrisoverson
Aug 1, 2018 05:39 PM
Punsisi Jayawardana
Dec 9, 2013 03:36 AM
Nubiebubie_GSX
Jun 7, 2006 02:16 PM
