Mitsubishi 380 Error code P0101 P0102 P0104
Old Apr 1, 2019 | 03:17 AM
Jarrod Wally Moreton's Avatar
Angry Mitsubishi 380 Error code P0101 P0102 P0104
Hi all,
I'm after some feedback from people who have had the same problem or someone mechanically minded?
I purchased a 2005 Mitsubishi 380 VRX DB Series Sedan in late 2014.
Odometer: 93,784 (at first service)
It's had some serious air flow issues which lead to the car to run rough, surge and even stall in traffic (usually when idle however on one occassion has stalled while going ~20km/h in peak hour traffic)
I have attached a list of issues specifically to do with the engine codes and the idling/stalling issues I have had since owning the car.
I've seen 3 seperate mechanics over my time with the car to no avail.
Replaced the air flow sensor, throttle body and had a few intake cleans.
Recently I have diagnosed that when disconnecting the air flow sensor while the car is running it continues to run. As far as I am aware the car should stall? Thus the air flow sensor I had replaced is now faulty itself.. Exactly 2 years after being fitted (it was brand new and genuine). I'm no mechanic but I feel like the air flow sensor should probably last longer than 2 years??
Likely a case of bad luck.
Anand
Jan 21, 2018 07:12 PM
Miles2Go
Apr 11, 2012 08:40 AM
mayo88
Jan 9, 2012 03:52 PM
