ETACS options customization
#1262
I'm trying to turn off TPMS on my outlander, for my winter set. I bought an adapter and 50 logins from the etacs decoder store. But i'm not sure how login is supposed to work and link up to my purchase?? Was i supposed to receive login information via email or something?
I read the instructions on creating an account on etacs decoder, but i get a counter of 000 instead of 050 next to my license?
#1263
I have cable, and received a disc. I suppose I should install in order to be able to link ED to my ETACS, or I must make some additional step?
and, my 2015 ASX has standard DRL, is possible turn off when the main light is turned on? I don´t like what are ON all the time
#1265
I thought my switch was broken when I got my car because it had no effect no matter how much I pressed it... Then I read the manual.
Stupid design though, it should give some indication that you pressed the button and what you should be doing to turn off ASC.
#1266
VCI mini won't connect
So I got the new VCI mini cable - the CD that came with it didnt work, but I was able to download driver, etc from other sources. When I run the Firmware Update tool, it shows the cable and shows it as connected. When I load ETACS_decoder_4_0_10_7, it won't connect. All four lights stay RED. What Am I missing here?
#1268
Help!!!
Got that to work, and I guess the cable works, as it destroyed my car and now I have the common 4wd system service and ASC system service req'd lights flashing. Ugh dont i feel like an idiot, after I made sure I wouldnt come back here with this question!!... why cant it ever be easy??
what now?
what now?
#1269
Don't panic, some options just got set incorrectly in the process. The software creates very detailed logs, Vadimus is a pro and he'll get you fixed up.
This happened to me once, but I managed to re-load my settings with the old software and no permanent harm came of it.
#1270
Still having trouble with TPMS.
I set line item #19 TPMS to "not present". But the car responds by throwing alarms for ASC and ABS and disabling them as well. I cycled the car a few times and drove it around the block, that didn't resolve the issue.
I need ASC and ABS for the winter. But how do i disable the TPMS without disabling ASC and ABS?? Is there another option i don't see?
