ETACS options customization
I'm trying to turn off TPMS on my outlander, for my winter set. I bought an adapter and 50 logins from the etacs decoder store. But i'm not sure how login is supposed to work and link up to my purchase?? Was i supposed to receive login information via email or something?
I read the instructions on creating an account on etacs decoder, but i get a counter of 000 instead of 050 next to my license?
I have cable, and received a disc. I suppose I should install in order to be able to link ED to my ETACS, or I must make some additional step?
and, my 2015 ASX has standard DRL, is possible turn off when the main light is turned on? I don´t like what are ON all the time
I thought my switch was broken when I got my car because it had no effect no matter how much I pressed it... Then I read the manual.
Stupid design though, it should give some indication that you pressed the button and what you should be doing to turn off ASC.
So I got the new VCI mini cable - the CD that came with it didnt work, but I was able to download driver, etc from other sources. When I run the Firmware Update tool, it shows the cable and shows it as connected. When I load ETACS_decoder_4_0_10_7, it won't connect. All four lights stay RED. What Am I missing here?
Got that to work, and I guess the cable works, as it destroyed my car and now I have the common 4wd system service and ASC system service req'd lights flashing. Ugh dont i feel like an idiot, after I made sure I wouldnt come back here with this question!!... why cant it ever be easy??
what now?
what now?
Don't panic, some options just got set incorrectly in the process. The software creates very detailed logs, Vadimus is a pro and he'll get you fixed up.
This happened to me once, but I managed to re-load my settings with the old software and no permanent harm came of it.
Still having trouble with TPMS.
I set line item #19 TPMS to "not present". But the car responds by throwing alarms for ASC and ABS and disabling them as well. I cycled the car a few times and drove it around the block, that didn't resolve the issue.
I need ASC and ABS for the winter. But how do i disable the TPMS without disabling ASC and ABS?? Is there another option i don't see?
