ETACS options customization
Old Jul 14, 2012 | 10:13 AM
  #361
andygb's Avatar
I will be grateful for your help
Old Jul 19, 2012 | 01:14 PM
  #362
Big_d_lou's Avatar
Just read through the whole thread. If I change the diameter of the tire size, will this fix the speedometer output also? I have an ASX with the stock 215/60/17. If I change it to something like 225/60/18 I will get a speed difference around 1.48x the original speed. If I alter the tire diameter in the ETAC to the new size will this correct the speedometer? I really want to fill up the wheel well with the speed discrepancy in the speedo. Not sure if the speedo is fly by wire now. Thanks
Last edited by Big_d_lou; Jul 19, 2012 at 01:17 PM. Reason: Auto correction ........ Sucks......
Old Jul 19, 2012 | 03:29 PM
  #363
Gen-8's Avatar
Just a little heads up on tire diameter throwing off speedo, if you can calculate the difference you can remove the speedo, open face, and re position needle to required difference.. Ie if it's 10mph out,and your doing 60, drop needle back 10mph so it'll be doing 50. Just a thought, I did it in my outlander. , the speedometer is not spring loaded like the old ones, it's motor driven without a mechanical return stop, it's all electrical now
Old Jul 20, 2012 | 10:06 AM
  #364
Vadimus's Avatar
Looks like there is a way to disable code request in 6.06+ diagbox.
Will post later today.
Old Jul 21, 2012 | 09:46 AM
  #365
Vadimus's Avatar
OK guys, I confirm DiagBox 6.19 working with no code requests for all 3 sections (vehicle, defaults, customer).
You need to delete lines containing
<Door Name="TLCD_ASSISTANCE_CODE" Number="4"/>
from C:\AWRoot\dtrd\comm\XMLTLCD\*.xml
I remind Out Sport/RVR/ASX owners than your vehicles are now in Diagbox as a Peugeot 4008 (Outlander is 4007). Though you can still manage your vehicles through selection of 4007/C-crosser, some ECUs (electric steering, push button start etc) will be shown only for 4008.
Old Jul 23, 2012 | 02:45 AM
  #366
Gen-8's Avatar
Vadimus, my etacs controller arrives tomorrow,mow iv never played with them before could you help a guy out on what I need to do lol.. Feels geek ish .....
Old Jul 23, 2012 | 03:05 AM
  #367
andygb's Avatar
Vadimus Did you check my problem
Old Jul 23, 2012 | 02:03 PM
  #368
galant2003's Avatar
from C:\AWRoot\dtrd\comm\XMLTLCD\I3_I4_COMBINE.xml
That is the information i am looking for
I will test it in the next days.
Regards
Old Jul 23, 2012 | 03:45 PM
  #369
Vadimus's Avatar
Not yet, sorry. With +37C outside and over +60C inside the car I am not much enthusiastic to sit in car these days...
Old Jul 23, 2012 | 10:14 PM
  #370
jsrd's Avatar
If this works in your Out, I have hope that can work on the mine. . .
