ETACS options customization
Old Sep 10, 2012 | 09:24 AM
  #461
goldfish2012's Avatar
Hi,
This is exactly what happened to me. Accidently downloaded the 4007 profile onto my ASX, i am still trying to find the way out.
To disable the 4WD, you need to go to 4007-> BSI manual configuration-> select the setting to 2WD / Front wheel only.
There are 2 setting need to be changed (i think is the 'Final drive' and 'transfer').
Originally Posted by asidrave
well now ive discovered more issues.
4wd lock service light is now flashing...i dont have 4wd
the door unlock when touching the handle does not work anymore.
the horn beep when activating and deactivating alarm does not work anymore.
ive tried to repair the issues via diagbox with no luck. ive tried using peugeot 4007 and 4008 with no luck in repairing. Is there another vehicle profile i can try to use to fix it?
My next option is to remove diagbox and install lexia and pp2000.
my car is a 09 lancer gts
Old Sep 10, 2012 | 12:37 PM
  #462
Big_d_lou's Avatar
Can you save then burn your settings in digibox and use it to configure another car? If there an option like that maybe I can save the settings of my asx and give it to you goldfish.
Old Sep 10, 2012 | 01:49 PM
  #463
Mart's Avatar
The only way out is to get a similar car, get in the configuration and take screenshot of all the default. Then reproduce the configuration on the "broken" one. I know, the same thing happen to me on an evo and I was able to 100% recover using this method.
that stupid apply default configuration option #$%#@$. They should at least log what have change or add an option to save it before...
Mart
Old Sep 10, 2012 | 03:15 PM
  #464
Big_d_lou,
Thank you. I will try to check to see if this is possible (I am still trying to understand the functionality of Diagbox). If this can be done, then it will be a great help.
Anyway, I also noticed that diagbox do not have all the access to the ECU like the MUT III. Here are the ASX default setting base on engine type:
CODING LIST
Old Sep 10, 2012 | 07:45 PM
  #465
asidrave's Avatar
Mart
I was thinking about that the whole day today...Getting a backup configuration or settings of someones Lancer GTS...lol. unfortunatly, I dont know anyone with a Lancer GTS or any Lancer for that matter.
If someone would be so kind as to sending me a screenshot of the default configuration of a 09 Lancer GTS
Old Sep 11, 2012 | 07:00 AM
  #466
Hi Big_d_lou,
What is your ASX configuration? Mine is:
Engine: 4B11 2.0, Petrol
Transmission: CVT 6 speed
Drive: 2WD With ABS, ASC and Hill start assist.
Safety: Driver, knee and front passenger airbag only
Without xenon lamp, no sunroof, without MMCS.
If the configuration are same or similar, appreciate you can share the diagbox setting with me.
Old Sep 11, 2012 | 07:29 AM
  #467
Mart's Avatar
Hi,
from where I can get the default for other model such as EVO, lancer etc? Would be very helpful in case of a problem...
thanx you
Mart
found some:
http://sportback.2de.ru/00/html/M100101500052800ENG.htm
http://outlander.2de.ru/00/html/M100101500020500ENG.HTM
Originally Posted by goldfish2012
Big_d_lou,
CODING LIST
Old Sep 11, 2012 | 09:40 AM
  #468
galant2003's Avatar
Here is the Coding List for 2009 Lancer Hatchback:
File Type: zip
Old Sep 11, 2012 | 10:52 AM
  #469
Big_d_lou's Avatar
Asx 2.0 petrol 4b11 cvt 2wd abs no hill assist or acs. 2 air bags only driver and passenger. I'll grab my setting tomorrow. I left my laptop in the office lol. Have tried reading the fault codes of the car? I had some fault code that I cleared. Then service light went away.
Old Sep 11, 2012 | 11:12 AM
  #470
Thanks. Yes, got fault code but cannot clear. fault code:
C1290
U1417
P1773
