ETACS options customization
Old Sep 11, 2012 | 02:07 PM
  #471
galant2003's Avatar
Originally Posted by goldfish2012
Thanks. Yes, got fault code but cannot clear. fault code:
C1290
U1417
P1773
C1290: CAN Time Out and
U1417: Variant Coding Invalid
may depend on ASC-System. Check Coding-Data in Etacs for this values. Erase the faults in both ECU. ASC and ETACS.
Old Sep 11, 2012 | 02:12 PM
  #472
galant2003's Avatar
Remember that if you have ASC the coding for ABS must set to not present and ASC to present.
Old Sep 11, 2012 | 05:46 PM
  #473
goldfish2012's Avatar
Hi galant2003,
Thank you for your feedback. I disable both ABS and ASC at the moment becuase when I enable the ASC, it showing 'ASC service required'. The fault cannot be cleared.
Old Sep 12, 2012 | 01:38 AM
  #474
Big_d_lou's Avatar
Hey goldfish I'm still trying to figure out how to output my settings with out my cable. I went to the office to use the laptop but for got my cable at home lol.
Anyway. Are you sure you have ASC in your ASX? I thought you needed to have 4wd for that. Try to disable asc first and enable abs.
Also try to download 6.08 DiagBox I think I was able to access the 2wd setting.
Old Sep 12, 2012 | 06:27 AM
  #475
Hi Big_d_lou,
Yes, very sure it got ASC. For the car with ASC, the ABS need to be disable and enable the ASC only.
For car with ABS only, then need to disable ASC and enable ASC.
No problem, just let me know the setting when you have a chance. Anyway, I will be away for the next 1 week.
Old Sep 12, 2012 | 02:41 PM
  #476
galant2003's Avatar
On site 29 Post 286 you can download the settings of an ASX 4wd...
Old Sep 14, 2012 | 07:41 PM
  #477
asidrave's Avatar
well i have been messing with diagbox 6.22 for a few hours trying to fix what happened with no luck. Im curently going to start fresh on a reinstalled copy of xp and im going to install pp2000 and lexia hoping that those 2 programs will work
Old Sep 16, 2012 | 04:50 PM
  #478
asidrave's Avatar
well guys...im at wits end trying to restore what was done. here is a recap.
Diagbox 6.22 peugeot 4007....i accidently hit a program restore to default and it did the following:
abs warning
airbag warning
4wd lock warning
horn conformation on door lock/unlock by remote not working
door unlocking by touching the door handle not working
maybe other things i havent found yet
I installed lexia and pp2000 and tried the same things with no luck. Can anyone suggest what i can try? Car runs fine...if i have to i will bring my car back to the dealer and have them restore the ecu. im not in a rush to do that.
Old Sep 19, 2012 | 09:33 AM
  #479
ivanz's Avatar
Have you tried unplugging the battery? I know some of those are straitforward options in the software, so it must be the settings not taking effect properly.
Old Sep 20, 2012 | 12:50 AM
  #480
asidrave's Avatar
I unplugged the battery overnite about 10 hours......same issue.
