ETACS options customization
Old Oct 1, 2012 | 08:54 PM
  #491
lordtygr's Avatar
Originally Posted by asidrave
Thank you lordtygr......i also replied to your pm from houstonlancers.com
I will hopefully get the current settings today and post it...been a busy weekend
uploaded. sorry it takes me so long but i hope this helps. obviously this is for my car. you may need to make any obvious adjustments for optional equipment you may/may not have.
http://www.houstonlancers.com/Lancer%20Settings.pdf
Old Oct 2, 2012 | 11:24 AM
  #492
asidrave's Avatar
Thank you soo much for this. I will check today after work and post results.
Old Oct 2, 2012 | 12:42 PM
  #493
galant2003's Avatar
Well bad news today
The dealer could not reprogram back to factory defaults. The told me it would not reprogram unless there was an update from mitsubishi which would open up programming mode.
The dealer is able to reprogram to factory defaults. Maybe they will not do that... If you get a new ETACS it must be programmed by MUT3. So there must be a posibility to do that. Maybe the dealer has to change any value step by step but it is posible.
Take the list of lordtygr and try yourself with lexia.
Good luck.
Old Oct 2, 2012 | 01:12 PM
  #494
ProcessorHog's Avatar
asidrave, I feel your pain. I did the same with my 2011 Outlander Sport once. What saved me was the settings that I had backed up just the day before. I had to go through each page, setting by setting and redo everything to the original value. Took me an hour and was a pain to get it done.
Here is the file if you'd like to take a look:
https://mitsubishiforum.com/forum/mi...29/#post280908
Old Oct 2, 2012 | 07:27 PM
  #495
Vadimus's Avatar
Originally Posted by Gen-8
Vadimus
How we going with that program?
Main developer (I just helped him a bit) was stuck upon writing settings back to ETACS.
There is some kind of CRC-like code for settings string to be accepted. No luck with that yet...
Anyway if someone wants to play here are the links for utility and driver:
https://dl.dropbox.com/u/23990187/ET...der_2_7_LT.rar
https://dl.dropbox.com/u/23990187/LEXIA-DRIVER-ED.rar
Old Oct 3, 2012 | 07:04 AM
  #496
asidrave's Avatar
Thank you lordtygr. I got it back working again. it took awhile plus i had to change some setting reguarding the optional equpiment i have.
Thanks everyone for your suggestions as well
with all the hours i have invested in programming and reprogramming my etacs, i feel like an expert now
Old Oct 4, 2012 | 10:59 AM
  #497
greatcat's Avatar
Hi Ivanz
I'm also in Vancouver with a 2010 Outlander XLS.
Can you help me make some change on my Outie? I'm thinking about auto lock function and fog light..
Thanks in advance!
Bob
Originally Posted by ivanz
Can you print our your config in PP2000/Lexia? We can compare it to our cars...there is an option somewhere to dump the whole config to the printer.
Old Oct 6, 2012 | 09:22 PM
  #498
ivanz's Avatar
Sure. Auto lock is easy but I don't believe auto fog lights is an option unless car comes with HIDs... I tried it on my 08 and all settings resulted it having to manually turn them on. PM me and we can meet up this weekend or something...
Old Oct 7, 2012 | 12:32 PM
  #499
lordnzo's Avatar
Default ASC Service required message!
Lordtygr,
What year and type is your car. I followed the settings and fixed all expect the asc service required. I have a 2011 Evo.
To make a long story short I was playing round with settings and defaulted the car to a crosser/4007!
Just trying to figure out what piece I am missing.
Thanks in advance!
Old Oct 8, 2012 | 07:28 AM
  #500
Vadimus's Avatar
Originally Posted by lordnzo
Lordtygr,
Thanks in advance!
lordnzo, which settings for your Evo you need to know/not sure?
Last week I turned off TPMS on someone's Evo (though 2009), I can have a look if I still have that log.
