ETACS options customization
Old Nov 25, 2012 | 05:09 AM
  #571
galant2003's Avatar
Originally Posted by Swordfish
Sir, which menu do I go to in Diagbox? When I click the fault menu under Vehicle Options (or is it Customer Options?), it says no faults found.
So there is no fault in ETACS but maybee there is a fault in another ECU.
Start Diagbox, read VIN and then start "Searching for faults" (translation from german) not "repair"
Old Nov 25, 2012 | 02:20 PM
  #572
galant2003's Avatar
@vadimus: can you explain how to activate "Low washer fluid warning"? I found it on a russian site to, but i didn't found the option for "Trailer turn detection" in Diagbox. I think about buying a fluid sensor and install...
Old Nov 25, 2012 | 10:10 PM
  #573
Swordfish's Avatar
Will try that later, thanks.
Question: How do I force the unlocking to driver door only on one press of the remote's unlock button and all doors for two presses?
I set this up this way using the remote (press and hold lock for 4 seconds-unlock-release lock-release unlock) before I got the cable. I no longer get a beep response now. Is it in Diagbox somewhere? Thanks.
Old Nov 26, 2012 | 06:36 PM
  #574
crank_18's Avatar
I have the Lexia unit up and running in the Ottawa Ontario, Canada Area if anyone from around this area is interested in getting their TPMS disabled pm me!
Old Nov 29, 2012 | 07:51 AM
  #575
rexer's Avatar
Hi guys,
I'm really interrested about purchasing the device for the TPMS but I also want to know if I going to be able to disable the "icy road alarm" with it because this alarm is as annoying as the tpms one.
Thanks!
Old Nov 30, 2012 | 07:42 PM
  #576
mitsuevo's Avatar
Default disable TPMS
can you disable tpms with the lexia on a 2011 mitsubishi lancer evolution ?
thanks
Old Nov 30, 2012 | 08:17 PM
  #577
Vadimus's Avatar
I can.
Old Dec 1, 2012 | 06:03 AM
  #578
mitsuevo's Avatar
Default tpms
im too far from you 7 hour, so i need to buy the lexia 3 ?
thanks a lot i appreciate
Old Dec 2, 2012 | 07:09 AM
  #579
rexer's Avatar
Hey Vadimus, are you able to disactivate the "icy road alarm" that we have aroud -3deg.C with the lexia.
Thanks.
Old Dec 2, 2012 | 04:14 PM
  #580
TrailBrake's Avatar
Thanks.
Actually that warning comes on at 3C, and I'm pretty sure that is one of the few things that can not be disabled at this time.
