ETACS options customization
Old Nov 23, 2012 | 10:36 AM
  #561
Swordfish's Avatar
Lightbulb
Originally Posted by galant2003
You can find it in "Programming by default". Look at Post 528. The option is there... It is named like "Auto door lock/unlock"
Thank you so much, appreciate it. I finally did it. Hopefully my sleepless nights are over. =B)
Old Nov 23, 2012 | 11:15 AM
  #562
MM3Canuck's Avatar
Originally Posted by Vadimus
Dennis,
Two stage/twilight mode is just what I wrote there:
Depending on an light brightness either stage kicks in.
DRL mode setting has several options, like being disabled completely, utilize HIDs or DRL bulbs, being linked to parking brake, staying on even with headlights engaged etc.
Thanks, yeah the attached links did not open for me. The DRL mode is very very interesting!!!
Old Nov 23, 2012 | 11:22 AM
  #563
Vadimus's Avatar
I believe forum engine was messed up. The post contains correct link, yet forum adds
Code:
http://apicdn.viglink.com/api/!m40223!
to links posted.
Not sure is it admin playing or forum was hacked
Won't post any links until the issue is resolved.
Old Nov 23, 2012 | 08:28 PM
  #564
Swordfish's Avatar
Default Engine lamp won't turn off
Oops, my engine lamp (the orange one) won't turn off. I only played with the headlamps, DRL and door autolock settings. Or maybe I inadvertently changed something. How do you think can I get rid of it? Thanks.
Old Nov 23, 2012 | 08:48 PM
  #565
Vadimus's Avatar
You have the tool, read the error.
Use Fault finding
Old Nov 24, 2012 | 07:48 AM
  #566
Swordfish's Avatar
Strange, the warning lamp is gone before I could even start to fix it. Hmm...
Old Nov 24, 2012 | 11:13 AM
  #567
galant2003's Avatar
Take the tool and read faults. Even when the lamp is off, the fault is stored. So you can check what was the problem and erase the fault.
Old Nov 24, 2012 | 11:22 AM
  #568
galant2003's Avatar
Vadimus,what do you think it takes to get the remote windows to work?
This option will not work for any models up 2011 which dont have one touch windows for passengers. To enable the function you have to change the power windows and the switches in the doors with this from up to 2011...
You can only change the type of power windows from "P4" (european version) to "P1". So you can change the time for delay of windows after turn of the ignition or open the door.
Sorry, for my bad english...
Old Nov 24, 2012 | 02:31 PM
  #569
galant2003's Avatar
I found many very interesting content about ETACS and the available options on this russian site:
http://mmc-autoelectric.org.ua/
With google-translator I can read in german ... on the english-site there are not so many information.
Old Nov 25, 2012 | 03:54 AM
  #570
Swordfish's Avatar
Sir, which menu do I go to in Diagbox? When I click the fault menu under Vehicle Options (or is it Customer Options?), it says no faults found.
