ETACS options customization
#511
Hello! I have trouble with coding etacs. I have u1417 error in abs. Car was coded to 4007 and after that asc lamp is on. I tried to change coding with lexia but without success. Car is outlander 3.0 v6, 2wd with asc. In lexia is no option for 6b31 and i belive that this is main problem.
CW6WXLMYL# 07 201211041142 1102000201000B82 8637A393 80103205200904086B006185422611041F00004A00001000CD 2281401A00024209801C4B20800200 80103205200904086B006185422611041F00004A00001000CD 2281401A00024209801C4B20800200 7A5A
That is your current config, do you have a previous one? Check c:\OUD folder.
#513
The very same page as you post, only dozen messages up
#515
Thank you
#516
Someone did messed up with ETACS settings and sold the car as-is?
#517
DiagBox Questions...
I received my Lexia device a few days ago. I installed DiagBox and have it upgraded to V6.19.
I successfully connected to my 2012 Outlander and was able to change the setting for rear wiper intermittent delay from 8 to 16 seconds.
As I understand it, the DiagBox program supersedes the PP200 and Lexia software programs. I am only running DiagBox. I do not see anywhere in either the Citroen nor Peugeot menus to:
1. disable TPMS
2. to enable auto door locking/unlocking
3. enable speed warning when exceeding 120 km/hr
4. enable independent operation of Fog Lights
Both Peugeot and Citroen menus for the CCrosser and 4007 seem identical and offer no differing selections.
Also I have come upon a screen seeking a username and password within the program. Any suggestions for that? ( I was able to activate it and generate the Customer Code,Version No., PC Identifier, Profile and Activation code)
Do I need to upgrade DiagBox to V6.22? ..or should I uninstall DiagBox and install Lexia and PP2000 software??
Any help/hints would be appreciated. In the meantime I will reread this thread for more understanding of this device.
Thanks
1. disable TPMS
Thanks
#518
I was just about to ask the very same question, as I am using DiagBox v6.19 and I wanted to disable TPMS on my 2009 Lancer Ralliart, but can't find a menu either on the Crosser and 4007.
How was TPMS disabled in DiagBox for the Evo?
#519
#520
DiagBox Question...
I have upgraded to V6.22. ( See two posts previous)
Do I need to authenticate when I am at the Home page ( Brand Selection)?
If so, what do I use as the IDENTIFIER and the PASSWORD in the Authentification Box??
