Extending Oil Change Intervals
Old Sep 2, 2011 | 10:25 AM
nesser's Avatar
Default Extending Oil Change Intervals
Originally Posted by cheech
OK, now that someone had mentioned it, I am now curious about it. the last post mentioned every 3K for oil change. Can the outlander go with out a change every 3K miles? im used to changing it every 3K miles, but if i can change my oil later that would be a great cost savings.
Extended oil change intervals can save you money and time but they definitely help the environment too.
Your car will generate 2 or 3 less used oil filters a year and possibly 10 to 15 quarts of used oil - depending on your oil change interval. You'll need a high quality oil and filter - some argue the filter is more important than the oil but they are both important when extending OCIs.
The issue is how comfortable you are extending your OCI while under warranty - I've yet to hear someone who maintains their vehicle have a lubrication problem by extending their OCI carefully with used oil analysis and common sense.
ALSO mentioned the type of oil Viscosity and certain climate changes, Im from NYC, i use 5w20, will using 5w30 be better off? where would viscosity be a factor on where you live.
Texas, Florida, Yukon etc. The oil suggestions from the manufacturer are tied to the ambient temperatures in the location you live - there is a chart in your owners manual. You'll be fine with 5W-20 in NYC. The hotter the outside temperature the thinner the oil will be at operating temperatures inside the engine (move up to a 5W-30). The colder it is outside the thicker oils do not lubricate as well during cold morning start-ups in the frozen north (stick with an 5W-20 or 0W-20).
The days of having to change oil viscosity based on the seasons are gone thanks to the multi-weight oils - the number with the W in front of it is for 'Winter'. The second number is the oil weight at operating temperature in the engine.
Who else is thinking of extending their oil change intervals or already does and what is your plan?
I'm going to start in the spring of 2012 extending to 12,000-km/6-month intervals on AMSOIL - Extended Life 5W-20 Synthetic Motor Oil (XLM) using a standard Wix or Mitsubishi filter until my 5 year warranty expires and then go to 24,000-km/1-year interval on AMSOIL - Signature Series 5W-20 Synthetic Motor Oil (ALM) using an AMSOIL Ea Oil Filters - Nanofiber Technology
UOA's will be done to verify that everything is good instead of blindly accepting the service life recommendations. I'll post them - but the first one probably won't be until next fall as I've got some other oil to use up first.
Old Sep 3, 2011 | 10:03 PM
Kwanger's Avatar
I change my oil every 7500 miles (as per the regular schedule). Being from Europe where everyone generally follows "regular" maintenance schedules and by and large experience no problems, I have to say I do not buy the "Every day to day car in the USA should follow the "severe" schedule" argument at all. In my time I've ran up a few 100k+ mile engines, and never had one pop because I didn't change the oil every 3k.
Old Sep 4, 2011 | 08:58 AM
GREG's Avatar
This also sheds some light on extending oil changing intervals. Here is some pretty interesting information.
https://mitsubishiforum.com/forum/mi...light=analysis
Old Sep 8, 2011 | 11:14 AM
Kwanger's Avatar
Thanks for the link Greg, very interesting. As mentioned, I've not done anything nearly as scientific as that...but my best example was my high mileage eurospec 1996 BMW M3 I had when I was stationed in Germany. That car was over 100,000 miles (with a good amount of sustained high speed autobahn abuse for the time I owned it!!) - and with that I only changed the oil when the BMW service indicator said it was time for a service....usually around 8-9000 miles. Always used a high quality synthetic; always took the time to thoroughly warm the car up before thrashing it. Sold it at around 120,000 miles and the engine was just as capable as when I bought it at 60k - it never did miss a beat.
Vadimus
Nov 26, 2010 12:13 PM
langone
Jun 10, 2006 03:30 AM
DClassical
Mar 30, 2005 01:07 PM
jgmacdaddy
Jan 9, 2005 12:49 AM
jacubsuk
Sep 7, 2004 05:34 PM
