Final pics of Aftermarket NAV install
Old Nov 19, 2007 | 08:35 AM
NothingInCommon's Avatar
Default RE: HELP!!! IS THERE A KIT 4 AFTERMARK. 2DIN NAV??????????
ORIGINAL: oldpapa1949
Whats the small white looking flex connector on the upper left of the bottom piece.
The Nav Kit is around a few hundred... I will check on my info later today.
Old
hmm.. not sure what piece your talking about..
thanks for looking up the info for me.
Old Nov 19, 2007 | 10:31 AM
If anyone is interested I am selling that ralliart panel Part #: RAY69013 since I wont be using it..
I never used it, I only took it out of the box to hold it up in these pics..
Old Nov 19, 2007 | 11:07 AM
chili_g's Avatar
ORIGINAL: NothingInCommon
I tried. It doesnt come off. Maybe I did something wrong.Either way, even if I did manage to pull it out, there is nothing to fasten it to. It would be dangling in behind the accent ralliart piece I have.
I was able to get it off OK, but your point about fastening it is true. It probably has nowhere to mount on the new peice. This is EXACTLY why I didn't bother waiting for an aftermarket dash kit - that circuit board is critical (airbag warning lights) and is integrated with the warning flasher button assembly. Good luck getting an aftermarket company to address that whole claptrap. This is also why the OEM nav fascia costs $150 - it includes that whole assembly.
Bugger...
Old Nov 19, 2007 | 11:11 AM
chili_g's Avatar
Oh, and the flex connector attaches to the radio faceplate - for the 6-disc unit, at least. It's a delicate little bit, so be really careful if you detach it... don't pull and prod - if you do it right, it comes out easily - if it doesn't, then you aren't doing it right.
I forget why it needs to connect to the radio... I think I figured it out, but can't recall.
You probably figured out that if you don't have that lower portion connected, your dash issues airbag warning / service required lights.
Old Nov 19, 2007 | 12:19 PM
ORIGINAL: chili_g
Bugger...
do you have a part number for the OEM nav fascia? Thats what I need.
Old Nov 19, 2007 | 02:06 PM
oldpapa1949's Avatar
Just bought the nav and kit off ebay.. A little under 1900 for both items and overnite shipping
He has a few left,
search for:
OEM MITSUBISHI LANCER & OUTLANDER NAVIGATION UNIT NEW
I did the the Make Offer and Got it.. U can look at the history of sales and find it as low as 1500. Kit be about 300.
Give it a try..
Old
Old Nov 19, 2007 | 03:14 PM
cutienoua's Avatar
The flex connector is to carry all the power and information to the display.I took it off and left only the airbag light module in order to use aftermarket radio.
Old Nov 19, 2007 | 07:00 PM
chili_g's Avatar
I don't know the P/N, but call this place http://www.mitsuaccessories.com/ and ask for Tim. That's where I bought mine. He'll be able to get it for you.
Old Nov 21, 2007 | 09:10 AM
ORIGINAL: chili_g
did it come with anything else? like the brackets that hold a NAV unit ?
Old Nov 23, 2007 | 08:16 AM
Ceram's Avatar
A repreasentative from Pioneer said that they will have a mounting kitfor the
Outlander ready before Christmas 2007. This kit will contain can adapter andwiring.
