front brakes squealing
Old Jan 8, 2016 | 06:44 PM
tweeder's Avatar
Default front brakes squealing
I recently replaced the front pads as the old ones were getting thin, no squealing issues. Bought the cheap pads as this isn't performance and is a wear item. Now i have bad hearing but the wife says they would squeal when applying the breaks, i let this go a week to see if it would go away and it didn't. So the parts guy brought me in a different brand and it was night and day difference, but now its starting to squeal again although not as loud. I already have the goop on to stop the squeal and i tried that with the first set to see if it made a difference and it didn't. So i'm back in there again and this time i had to pry the caliper off as it seemed tighter. I got the wife to apply the brakes ant pop the piston out a little ad it does go back in but not all the way and i am able to press the piston back in with ease with the piston tool so i don't believe its stuck. Any suggestions? I have lubed the sliders and it has new shims, the rotors look good with no grooves although now might be a little darker? didn't pay much attention, might bring them in and get them turned.
Old Jan 8, 2016 | 09:27 PM
Lancerguy2013's Avatar
Hmmm...I've always gotten at least one..maybe 2 pad slaps out of a factory set of rotors. I always use OE pads that I buy from the dealer though..so that might be a factor.... never had any noise or vibration issues doing it that way.I have used Wagner Thermo-Quiet on some older vehicles with good results as well..no noise with those either. Good Luck !
msport_2_outlander
Jan 9, 2015 07:30 AM
Subydrift
Mar 10, 2009 09:47 AM
anthony_piaa
Apr 1, 2007 11:43 PM
Wagoner
Feb 3, 2007 12:41 PM
00GalantMan
Feb 6, 2006 01:31 AM
