Front end /steering vibration
Old Jan 15, 2025 | 12:10 PM
silverbarry's Avatar
Default Front end /steering vibration
I recently replaced Sway Bar Links, Inner and Outer Tie Rods - both sides on my 2012 outlander gt. My original problem was vibrating in the front end at 80 mph - acting like the tires were out of balance. My local tire shop said I needed to repace outer tie rod ends. I did a lot more. Now not only does it vibrate at high speeds it wobbles has a mind of it's own and does not return to center unless you help with steering. The steering really is in pretty bad shape. I need to have both hands on the wheel most of the time. Also I'm quite sure theses are bad tires which have caused me grief since day one. The car stops straight but has not been aligned since the work. H E L P please.
Old Jan 16, 2025 | 09:19 AM
Outlaander's Avatar
From the service manual: I would also carefully check the condition of the wheel bearings. Outlanders are known for having to have them replaced sooner than expected.
Old Jan 20, 2025 | 06:53 AM
So the good news is getting 4 new tires balance and align my problem is fixed. The bad news it cost me 700 dollars. I bought "bad" tires a year ago and fought front end and balance problems for a whole year. I was desperate.
Old Jan 20, 2025 | 01:15 PM
Outlaander's Avatar
Good for you! And now you have some nice new parts that are going to last a long time. Enjoy the smooth ride!
nativa
Dec 4, 2023 11:17 AM
SERPENTOR
Oct 10, 2014 03:16 PM
athlete1012
Aug 19, 2008 06:45 PM
Liquid_force
Mar 10, 2008 10:31 PM
Nuggethead 420
1st Generation
56
Oct 6, 2005 12:42 PM
