Galvanic Corrosion at Wheels?
Old Nov 2, 2008 | 01:36 PM
foy1der's Avatar
Default Galvanic Corrosion at Wheels?
Hi,
I just finished installing my mudguards and I noticed something when I took the rear wheel off. Does this look like galvanic corrosion to anyone else? I imagine that the wheels are Aluminum and I am also assuming that the studs that the lug nuts screw onto are steel. If the two touch you would get galvanic corrosion. Anyone else seen this or do you have any thoughts about it?
Old Nov 2, 2008 | 08:46 PM
Shambala's Avatar
Default RE: Galvanic Corrosion at Wheels?
Is that a 2007 or 2008 Outlander?
I haven't had the pleasure of taking the wheels off my 08 yet ... I want to clean some of the rust out (if any) and put a protection plate in between...
However your photos seem like normal wear and tear to me, unless it is a new 08-09 model then something is totally wrong...
Old Nov 4, 2008 | 01:45 PM
ronwill's Avatar
This looks like the normal raection between different metals ;.......see my posting of a few months ago: https://mitsubishiforum.com/m_219896/tm.htm
A 'smear' coating of Copperslip grease between the surfaces cured my problem. I would advise everyone to do the same before winter sets in!
With ref to comment re rotation of wheels,this is not a recommended procedure in Europe but I do swap front to back when signs of wear present themselves!
Ron
Old Nov 6, 2008 | 10:00 AM
bnilguy's Avatar
I had a bit of corrosion when I used chrome valve stem caps...I ended up spray painting some plastic caps aluminum colored. I agree with Ron, If you use metal..put some anti seize on them to prevent corrosion
Sodium
Oct 12, 2011 11:22 PM
roach
Jul 29, 2008 11:01 AM
GalantGTZ
Jan 23, 2004 10:17 PM
protopwr
Oct 29, 2003 07:04 PM
SasSi
Aug 12, 2003 02:19 PM
