Gas
Old Aug 26, 2012 | 06:51 PM
milliesdad's Avatar
I've put in my first tankful since picking it up on Monday night-put on 300 milles this weekend.
On the tank of what the dealer had in, according to the computer, I got 27 mpg. I filled up on regular for the return trip and got 24 mpg.
It might b e cost-effective to use the higher octane.
Around here, there is 1 gas tank farm,and all (BP,Shell, Mobile Kwiktrip, ect all comes from the same tank farm. The Holiday stations from the UP come down here to get product.
Old Aug 29, 2012 | 08:37 AM
theewz's Avatar
87 for me, usually from costco. I get about 420-450KM before I need to fill, which is about 1/4 tank left. seems pretty decent for an 08 outlander.
Old Aug 29, 2012 | 04:51 PM
ccernst's Avatar
87 here. That's what my engine is spec'd for.
Higher octane does not mean more performance from the fuel alone...it means fuel does not combust as easily.
Old Aug 29, 2012 | 09:35 PM
cheech's Avatar
so does that mean the higher the octane = better mileage?
Old Aug 29, 2012 | 11:52 PM
OutlanderGT's Avatar
no. The higher octane would benefit from the higher compression of 2010+ V6 models, the higher octane lets the ECU run more advanced timing and generate more torque using the same amount of fuel, which means your have a little better gas mileage.
Old Aug 30, 2012 | 03:04 PM
ccernst's Avatar
Exactly right. The only con is that the fuel is more expensive.
To use higher octane, you need higher compression. Vehicles with turbos and superchargers will use higher octane.
Old Aug 31, 2012 | 08:36 AM
cheech's Avatar
I have a 2007 if I was to put higher octane in my car when I get better mileage? Or it wouldn't matter. If not mileage boost, what about performance?
Old Sep 1, 2012 | 06:47 AM
milliesdad's Avatar
No. If your engine iis spec'ed for 87 octane, then the premium would not help mileage. If your engine is "recommended " to use premium, then maybe.
Old Sep 2, 2012 | 03:55 AM
Gen-8's Avatar
Still six that the mpg or kpt is so low, I'm tempted to put a engine transplant in with that kind of consumption!! Otherwise I'll try flash my ecu with a different map first and curb some excess fueling mitsi gives and dyno it before and after and with the manifold system etc
EVOIXGUY
May 14, 2013 05:07 PM
chevegan
Oct 6, 2010 03:52 PM
wmlove3
Aug 9, 2010 10:53 AM
wu2001ok
Jul 2, 2003 01:30 AM
JohnR
Jun 4, 2003 08:31 PM
