ground wires
Old Apr 22, 2005 | 07:51 PM
wicked_outlander's Avatar
Default ground wires
guys knoe the locations of all ground wires??? just bought a aftermarket ground wires system.( engine set up )
Old Apr 25, 2005 | 06:58 PM
Default RE: ground wires
huh?? nobody knoes..... [:@] hmmm.....
Old Apr 26, 2005 | 02:54 PM
JMC's Avatar
JMC
Those are usually Vehicle specific kits..........
What kind did you get? Separate Type, or Direct type?
Old Apr 28, 2005 | 04:12 PM
Tom Q's Avatar
I've seen a pic of the ground wire system. It looked like spider webs mounted on the battery pole and spreads out. What is this system for anyway?
Old May 3, 2005 | 03:24 PM
JMC's Avatar
JMC
To make yr Outlander kick ***!
Old May 12, 2005 | 11:54 PM
ORIGINAL: JMC
its a seperate type from sun automobile of japan.
Old May 13, 2005 | 02:31 AM
crunchie's Avatar
Basic ground wire systems are intended to give you better "grounding", no pun intended. The negative terminal of your battery is connected to the rest of the car via the metal frame of your car. Of course, there's the alternator also but your car's frame is still the major conductor.
Do a search, this has definitely been discussed a bunch of times and explained in more detail.
Old May 14, 2005 | 02:34 PM
i'll try that...
Old May 16, 2005 | 02:38 PM
JMC's Avatar
JMC
Does Sun Auto say anything about how it hooks up to yr Outlander?
Old May 16, 2005 | 05:27 PM
ORIGINAL: JMC
nope' its a universal configuration....but they do have one for 00' eclipse rs /gs, which is pretty much same engine w/ the outtie.
00Mirage
Jun 19, 2006 08:42 PM
Blk95SL
Jan 12, 2006 03:15 PM
wicked_outlander
Apr 22, 2005 06:18 PM
aswahdan
Nov 12, 2004 10:25 AM
1398spdr
Aug 27, 2004 03:27 PM
