havoline vs. dia-queen j2??
Old Jul 6, 2015 | 07:58 AM
07xlsguy's Avatar
Default havoline vs. dia-queen j2??
Looking to do a trans drain and fill this weekend. can anyone tell me if havoline dextron vi will work? it says compatible with J3.. My 07 xls V6 calls for J2.. If not , is there a cheaper alternative than dealer j fluid? I have searched the forum and cant find a definite answer for the havoline j3...THANKS
Old Jul 6, 2015 | 08:53 AM
gggplaya's Avatar
Just buy the J2, probably only need about 4-5 quarts if not doing a flush and it's $12 a quart at the dealer. $60 is alot of money, but it's only something you do every so many thousands miles.
Old Jul 6, 2015 | 09:20 AM
White92VR4's Avatar
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
Page 2, top right. Havoline Dextron VI is ATF J2 and J3 rated.
I used it for my 10 GT S-AWC 2 months ago, works great. I did the full flush buy using the method of removing the lower cooler line process found on here in a sticky post.
Was $55 for 12 quarts from Amazon with free shipping.
Old Jul 6, 2015 | 03:16 PM
Outlaander's Avatar
Thanks for that link! My wife and I have a 2010 XLS, too, and this is a much less expensive option than the Diaqueen.
I assume that you do not think that flushing your AT with the Havoline will void the drivetrain warranty. I can't help but wonder if Mitsubishi feels the same way now that some owners are robbing them of their pound of flesh.
Old Jul 6, 2015 | 03:44 PM
White92VR4's Avatar
I am the second owner so the 10/100 drivetrain is not in effect. It now has 82k on the clock. I do have a 4/48 aftermarket warranty and feel that if I did not do preventative maintenance they could void the warranty for that. I feel they would have a hard time claiming an issue if I am doing what I can to prolong the life/condition of the vehicle.
I followed the factory service manual to the letter. The only thing I did do was capture and carefully measure how much I removed in each of the 3 steps and re-added only what I took out of it at each step.
I ended up using just over 9 quarts.
I am currently on a 2500 mile trip out east now and the tranny has been flawless. Havoline Dextron VI is good to go.
Old Jul 6, 2015 | 04:00 PM
Outlaander's Avatar
Fantastic, and I'm glad your vehicle operates well with the Havoline!
The reason I mentioned the warranty is that here in Canada the original 10/yr - 160,000 km warranty is fully transferrable to subsequent owners. It's a great selling tool for Canadians who are selling used Mitsubishi vehicles whose mileage is still under the age/km limit. The new owner gets a used vehicle that actually has a full factory warranty for at least some period of time. How can either party beat that?
Anyway, thanks again for the great tip about the Havoline.
Have a great trip!
Old Jul 7, 2015 | 02:43 AM
SERPENTOR's Avatar
2008 Mitsubishi Outlander XLS can use AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid
Applications
AMSOIL Signature Series Fuel-Efficient Synthetic ATF is recommended for transmissions and other applications that require any of the following specifications:
Ford MERCON® LV, SP; GM DEXRON® VI; Aisin-Warner AW-1, Audi G 055 005, G 055 162, G 060 162; BMW 83 22 0 142 516, 83 22 2 152 426; Honda DW-1®; Hyundai/Kia SP-IV, SPH-IV, SP-IV-RR; JASO 1-A; JWS 3324; Chrysler Mopar® P/N 68157995A (ZF 8&9 Speed ATF); Mercedes-Benz 236.12, 236.14; Mitsubishi SP-IV, ATF J2; Nissan Matic-S; Saab 93 165 147; Shell M-1375.4, M-1375.5, M-1375.6, M-L 12108; Toyota WS; Volkswagen G 055 005, G 055 162, G 060 162.; Volvo 97342
If anyone would like to know what AMSOIL products are available for your vehicle go here
https://www.amsoil.com/whymygarage.aspx?zo=1692866
Old Jul 7, 2015 | 07:29 AM
07xlsguy's Avatar
Thanks White92VR4---and BTW.. thanks for the info regarding the sway bar end links... replaced them and the sway bar bushings--all noise gone and feels as good as new again!
mda185
Jun 3, 2013 02:29 PM
Broncoman75
Apr 25, 2012 02:26 PM
nesser
Mar 13, 2012 08:55 PM
GREG
Sep 21, 2011 05:54 PM
ronsin1
Jul 27, 2009 11:03 PM
