Headlight Highbeams Issue
Old Aug 7, 2019 | 02:44 AM
SERPENTOR's Avatar
Default Headlight Highbeams Issue
I have a 2008 Mitsubishi Outlander XLS V6 and had the Highbeams Headlight Bulbs (HB3) replaced and now when I turn them on at night it seems that only one side (the leftside) projects and is visible. The right-side highbeams is on it is just not projecting forward or producing a beam of light like the left side. What can be wrong? Is it a bad bulb possibly?
Old Aug 8, 2019 | 10:25 PM
SERPENTOR's Avatar
http://imgur.com/gallery/Sw8JNsE
The right side Highbeam does not illuminate or project as much as the leftside. What can be wrong?
Old Aug 9, 2019 | 09:15 AM
Matt101's Avatar
I had exactly this issue with my High beams. Turned out I hadn't located the bulb correctly. Took it out and re-fitted it and sorted.
Old Aug 9, 2019 | 05:29 PM
SERPENTOR's Avatar
Does anyone know if there is a YouTube video or instructions on how to change the Highbeam bulb on the 2008 Mitsubishi Outlander XLS?
Old Aug 10, 2019 | 04:53 AM
Matt101's Avatar
If they are the same as mine HB4 or HB3 then 1/4 turn anticlock and they come out. Disconnect cable and reverse back in. Socket should be pointing down when correctly fitted
outlandergt2014
Sep 2, 2014 01:38 PM
Stephen Nguyen
Oct 5, 2013 04:06 PM
Lobosmom1
Jan 10, 2011 09:49 PM
MonteroDude2
Oct 9, 2009 01:52 PM
boosty
Aug 12, 2004 02:41 AM
