Help Needed rear abs sensor
Old Apr 2, 2017 | 06:13 PM
Colchester's Avatar
Default Help Needed rear abs sensor
Hello I have a 2009 Outlander AWD. I am getting a P1773 code and ABS light as well as asc and 4 wheellock warnings. I did some investigation and found that the drivers side rear abs sensor is no longer cliped into the slot that secures it in place. I tried to re install it but the clip and slot are rusted and deteriorated. Is the housing that secures the abs sensor available as a part by itself or does it need to be replaced as part of the wheel bearing assembly. I would like to get the needed parts before tearing into this. If the bearing needs to be changed are there some bearing brands that should be avoided. Thanks for any help you can provide
toad
Feb 7, 2012 11:52 AM
tizzo
Aug 3, 2010 11:52 PM
tizzo
Jul 7, 2010 01:51 AM
fallingapart3000gt
May 13, 2006 01:35 PM
vertstanggt
Jan 13, 2006 07:29 PM
