How to reprogram key fob help pleas
Old Jul 3, 2013 | 03:20 AM
Doc123's Avatar
Default How to reprogram key fob help pleas
Morning all I've a.2010 outlander with two keys ( bladed type ) one of he keys will not lock or unlock car by the fob it will manually open and lock and start the car but if the car was last locked by the other key fob and I open it with the non working fob the alarm sets off ... I have put a new battery in but no joy and was wondering if there is a way to connect the key back to the car or is it a dealer correction
Old Jul 9, 2013 | 09:44 PM
blitzkrieg79's Avatar
I had issues with my key fobs on a couple of occasions with my 2009 Outlander. There is a reprogramming procedure in the manual but basically what happened to me was that the first key fob stopped working, so I tried to program it following the manual instructions but I couldn't do it (as a note, according to the manual one of the key fobs has to be working in order to initiate the procedure). So I have used the second key and after a while it also stopped working. So I went to a dealership and they reprogrammed it free of charge and they couldn't tell what caused the problem (only speculation such as cell phone interference). I have also replaced the batteries in the key fobs but I am suspecting that the module inside the car might get damp (due to humidity) or something and that's what is causing the deprogramming. When pressing the key fob, the red light on the key fob always turned on so battery was not an issue.
Old Jul 10, 2013 | 06:55 AM
Doc123's Avatar
Sorry for late reply .. It's seems the key had lost its code .. I did think about trying to reprogram it according to the manual but was worried I'd end up with two duff fobs, so a call to the dealers was made one dealer wanted £60 + vat but found another dealer would do it for £45 + vat so had it done there .. The mechanic said that they could go faulty if ts been through a scanner ie airport or left by a router .. But as neither was the case with my key fob I'm still none the wiser why it lost its code just £45+ vat lighter
Old Jul 11, 2013 | 03:10 PM
Akzle's Avatar
electric things do things some times.
there is usually a button somewhere that you press down (on the vehicle) which broadcasts the code algorthm to anything that's listening, then you press and hold a button on the fob, to tell it to listen, the light will flash fast a few times, and it'll be sync'd up.
noobynoo
Feb 7, 2012 04:37 PM
MILITARYIMPORTNUT
Sep 8, 2011 07:54 PM
Galanthighspeeder
Sep 6, 2011 10:34 AM
Elisha
Feb 18, 2011 03:59 PM
mitsu41
Jul 7, 2006 04:22 PM
