How to unlock MMCS
#381
I replaced HDD direct to my 2008 Outlander, the map orginally were 2006 now I have 2011 with good coverage of Greece and all Europe. All other MMCS software works well.............
#383
Hey!
I Need help - for C-Crosser edition C-01
I will update the Navi or and a second Navisystem Install on HDD
and use mp3 and more.
I have:
Versions Indication
Loader BLD-NR-261EM-CTR 1.10
Application 10.40.01
Navi Sub Microcomputer 00.31.00 090004
Audio Microcomputer 09.34.03 093403
Map Data I170 AEU_08_200902C
Monitor 00.27.00
CAN BOX 000126
Unterstützungs-Info
SW-Version G
Kartenversion 2009-A
CDDB-Version 1626-3948
I have download the xboxhdm file, i don't find the excel for the password!
Thanks for your help!
I have:
Versions Indication
Monitor 00.27.00
CAN BOX 000126
Unterstützungs-Info
SW-Version G
#385
Hello everyone, first id like to thank the ppl that made MMCS hacks possible.
Ive run in to a wierdl problem tho, and maby some one can help.
Ive unlocked my oryginal Toshiba drive without any problems, then i cloned it to a Fujitsu 40GB that i had around from some old laptop.
I connnected the fujitsu drive to mmcs it worked perfectly, navi, music server everything works.
Once i checked if the cloned drive works i took it back to my PC and found out it got locked by mmcs (which is normal i know) .
The problem is i cannot unlock the fujitsu drive using the password from the tutorial anymore.
The orginal drive can be unlocked many times without a problem, yet the fujitsu even tho it works in a car cant get unlocked anymore (and i know that its password protected again)
Any one alse had similar problems with other manufacturer drives, or is it just that model than i happened to have ?
#387
I tried unlocking with both master and user passwords, I also tried warious password lenghts, hd manufacturer master password, laptop manufacturer master password, nothing seems to work.
Funny enough the drive works perfectly in the mmcs, well i got a hold of another Toshiba drive, and this one can be unlocked normally every time, just like te orginal.
I dont realy care if the fujitsu drive stays locked, it was just laying around anyways, its just interesting that it got locked and cannot be unlocked using standard passwords.
jooi - have you tried unlocking with the user, or master password ?
NavHack!
NavHack!
#390
Hi there, just wondering if anyone can help me, I recently bought myself a Mitsi Galant Fortis, it's the exact same as a lancer. The year of the car is 08, anyways the MMCS that came with the car is all in Japanese, now I would really appreciate some help with trying to change it from Japanese to English, or even a video or directions on how to get Bluetooth working with a Japanese car, I know it works because I nearly got it working today but just couldn't figure out how to Sync them together.
So if you know how to setup Bluetooth on a Japanese MMCS, or change Japanese to English can you message me back. Cheers
