How to unlock MMCS
Old Mar 30, 2014 | 01:14 AM
  #531
andyf97's Avatar
Default mmcs
Could somebody please send me the entire European HDD partition contents without the maps to andy f 97 98 at hot mail dot com using wetransfer.com
Mine is corrupt and I do not know anyone near me with an Outlander.
each partition contents as a separate zip would be great.
Old Mar 31, 2014 | 05:55 AM
  #532
mercenary's Avatar
Originally Posted by Vadimus
Disable primary IDE in BIOS.
thank you it worked!
Old Mar 31, 2014 | 06:07 AM
  #533
mercenary's Avatar
Seems that my HDD failed and i dont have correct image.
Can i copy files from my friend HDD to a new PATA 2.5" HDD?
Both HDDs have been unlocked with the same EUROPEAN key B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEBAB2DFB19E8996DFAA8C9A8DDFDF
Are there any more compatibility requirements except that both EU versions?
In that case software wouldnt be supported - wont it brick my navi system ?
Old Mar 31, 2014 | 07:29 AM
  #534
Vadimus's Avatar
Stuff deleted.
Old Apr 1, 2014 | 07:21 AM
  #535
HJB's Avatar
HJB
Also a GAC model HDD will make sure that it works which is the Auto grade. I 've tried other models e.g. GAS and they will not work.
Old Apr 24, 2014 | 12:34 AM
  #536
Nugjii's Avatar
Question MMCS Version
Dear my friends
I have a Outlander 2007 model with MMCS TV and Navi. My car japanise version. I'll try to flash with English interface.
How to know my MMCS version? (J-01, J-03, R, N etc)
Old Apr 24, 2014 | 08:02 AM
  #537
Vadimus's Avatar
It is written below the joystick.
Old Apr 24, 2014 | 02:01 PM
  #538
JGRMan's Avatar
Hi all,
I have a Japanese MMCS J-03.
Any advice on how to convert to English as a start would be greatly appreciated.
Old Apr 24, 2014 | 02:41 PM
  #539
mortod's Avatar
mercenary - are you in the UK? I might be able to clone my disk to a new disk and post it to you for a small charge. My HDD failed recently (rather, I bought an Outlander with a failed HDD). In my case the damage was confined to the last partition where the music is stored, and I was able to re-format that partitaion and get the original HDD working. I have since replaced with a £10 non auto grade HD and it seems to be working well. I'm just keeping it backed up in case it does become a problem. Roads here are pretty rough and that hasn't been a problem yet, and temperatures in UK unliekly to be too hot, so I'm not convinced an auto grade disk is required.
Old Apr 24, 2014 | 03:13 PM
  #540
Vadimus's Avatar
E-0x (European market) MMCS HDD won't work on J-0x (JDM)
