How to unlock MMCS
Old Feb 28, 2016 | 08:10 AM
  #651
chanaum's Avatar
Hello
i am french .Next week i remove the 2 accus for change.Now my MMCS dont work.On screen i have insert a program disk.Do you now what happen? i remove the original TOSHIBA HDD mine is unlocked,and i connect on my laptop ,i see all parts.
Is that possible that the HDD is dead?
Thanks for your reply
Old Jul 17, 2016 | 01:46 PM
  #652
konohakyuubi100's Avatar
Default MMCS j-13
I have a 2015 outlander PHEV Japanese imported with the j-13 MMCS. Do anyone know how to convert this to english.
It has no HDD only 2 SD card slots.
One slot has a SD card which is inaccessible via the computer.
Old Jul 17, 2016 | 01:55 PM
  #653
Originally Posted by rntip
Hello Falken72, I am completely new in this Outlander MMCS world.
My european Maps (Portugal) are form 2005, can you help me to update it?
No need to unlock your hard disk. Go to mitisubishi European site and you have updtade to download from there and follw the instructions
Old Aug 3, 2016 | 04:59 AM
  #654
michalez's Avatar
i have updated map but after update there are new poi category but i cant see any icons and names in this categorie, anyone knows how to solve problem?
Old Oct 2, 2016 | 09:58 PM
  #655
teeboz's Avatar
Originally Posted by rcostin
ANY MODIFICATION ON HARD DISK MAY ALTER MMCS CAPABILITY TO LOAD DATA. DO IT ON YOUR OWN RISK.
The tools needed:
I would try to update my navi using a copy from another disk.
The tools needed to unlock the hard disk are below:
1. One screwdriver
2. One torx size 8 (see img)
3. One IDE adapter from small form to regular IDE (see here and here - both sides) if you use a desktop PC. For laptops, it connects directly.
4. The unlockhd program from iso file (the package is available here or here). You have to write it on CD and boot from it. NO OTHER HDD SHOULD BE ATTACHED EXCEPT THE MMCS' ONE.
5. The unlock key: B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEBAB2DFB19E8996 DFAA8C9A8DDFDF - for loader version 261EM (or B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996 DFAA8C9A8DDFDF for 261UM)
6. One computer with IDE bus.
Procedure
1. To find out what loader version you have:
a) hold SET+NAVI for about 5 seconds to enter "Service Mode" menu
b) press Version Indication
c) note somewhere the Loader version. The key calculation algorithm is presented below. For example, for 261UM version, the key is B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996DFAA8C9A8DDFDF (I bolded the difference between 261EM)
2. Flip the screen (push OPEN button in the lower left corner), pull the HDD plastic cover, gently.
3. Unscrew the two screws which holds the hdd. Use the torx. Pull out the hdd.
4. Connect it to IDE bus and power supply.
5. Start the computer, boot from CD, and pick option 3: "Boot linux with locking/unlocking utilities"
6. Wait for root@Xbox-HDM:/1 prompt
7. type unlockhd -p (Ex. unlockhd -p B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEAAB2DFB19E8996 DFAA8C9A8DDFDF). Double check if necessary !!!
8. The key depends from unit to unit. See below.
9. If the operation is successful, running fdisk -l command will show the partitions (very similar as below). (thanks rcpax [sm=smiley20.gif])
10. Now you may turn off the computer. The disk is unlocked. You may use it with a Windows computer as a regular disk.
Key computing algorithm
Thanks to brian360, the string sniffed when MMCS negotiate with the hdd is
BAB2 BCB3 DFB0 BEAC BBB1 DFBE ADB1 CDD2 CEC9 B2AA B1DF 899E DF96 8CAA 8D9A DFDF
The password is 32 bytes long but transferred at 16 -sixteen-bit words, so the MSB of each byte is high. It turns out that if you invert all of the bits of the password you get this:
454D 434C 204F 4153 444E 2041 524E 322D 3136 4D55 4E20 7661 2069 7355 7265 2020
Decoded ASCII is:
"EMCL OASDN ARN2-16MUN va isUre "
After swapping the byte ordering around you get:
4D45 4C43 4F20 5341 4E44 4120 4E52 2D32 3631 554D 204E 6176 6920 5573 6572 2020
which in ASCII is: "MELCO SANDA NR-261UM Navi User "
MELCO - Mitsubishi Electronics Company
SANDA - the company's Sanda Works facility
NR-261UM - loader ID
The password used with the 'unlockhd' command was actually byte swapped, so if you try it, use this as your password:
b2bab3bcb0dfacbeb1bbbedfb1add2cdc9ceaab2dfb19e8996 dfaa8c9a8ddfdf
An excel sheet to exemplify the algorithm is available on PM. It requires Analysis ToolPak from Excel Addins.
The disk is locked again when you insert it in MMCS unit.
I just put all this stuff together to be easier to understand. Thanks brian360, otaku, GPSeek, oly_57mpg and all the others I could omit.
[IMG]local://upfiles/13524/2FA3CDC58A5E4070B458F921708B22D5.jpg[/IMG]
I know this is an old thread, but does anyone knows if these passwords still work for mygig rhb 2013 radios on firmware 50.01.01
Old Oct 3, 2016 | 09:25 AM
  #656
Vadimus's Avatar
I wonder what "mygig rhb 2013" is...
Old Oct 3, 2016 | 10:55 AM
  #657
Alsam's Avatar
Default Unlock mmcs
Hello I myself is stuck in this situation any help will be greatly appreciated my nane is Albert I recently purchased a Mitsubishi galant sportback 2012 and is fitted with a Diatone NR-MZ 60 but it's locked.
I was wondering if there is anyway I could get the reboot software? Providing this will resolve this issue.
Old Oct 3, 2016 | 10:00 PM
  #658
teeboz's Avatar
lol radio in Chrysler and jeep vehicles have simular locking system
Old Nov 18, 2016 | 07:48 PM
  #659
teeboz's Avatar
Default Thanks to post
Got the RHB430n Chrysler, jeep password figured out. For any chrysler ppl looking for a password for this unit it is:
1) B2BAB3BCB0DFACBEB1BBBEDFADBDA5DFBE8A9B9690DFAA8C9A 8DDFDFDFDFDFDF
2) B2BAB3BCB0DFACBEB1BBBEDFB2BEACBCDFAF8D909B8A9C8B8C DFB29E8C8B9A8D
3) B2BAB3BCB0DFACBEB1BBBEDFADBDA5DFBE8A9B9690DFB29E8C 8B9A8DDFDFDFDF (RBZ Only - SWDL_CPU0.mbi)
these passwords are
Embedded in Main_APL_CPU0.mbi file.
Old Jan 14, 2017 | 06:17 AM
  #660
Outie2011's Avatar
Default HDD clone problem
Hi, I solve this problem: My friend has E-03 with a dead HDD. I made a clone on the new HDD from my E-02, but the problem continues. Navi still shows: Insert program disc.
Can you please advise?
Thanks
