Jacking points / Jack Stands
Has anyone found good places for jackstands on the 07/08 Outlanders? Same question for jacking points(especially with large based floor jack). Have to rotate my tires and haven't taken a look under mine yet.
I was going to jack mine up when i installed my hitch, but couldn't find any good spots to put a hydraulic jack. There's very few flat spots and the frame rails appear thin. The manual shows specific points for the OEM jack, but they didn't look so solid either...sits on a lip of sheet metal.
I'd like to hear what others didtoo.
ORIGINAL: Cuffy
I'd like to here what others didtoo.
ORIGINAL: roach
I use the OEM specified point from the manual to put my hydraulic jack to change my winter tire to my summer and everything was fine.
ORIGINAL: Cuffy
ORIGINAL: n0c7
Where did you place your jackstand on the other end while the jack was holding one end up?
ORIGINAL: roach
ORIGINAL: Cuffy
I can't believe I looked through the manual and full of fun and some uesless info but I cannot find any information about where to place a floor jack and jackstands.
Obviously it the jackstands would go on the scissor jack point (if needed) but where to lift the vehicle with a floor jack?
So I would jack up the front, put 2 jackstands, then jack from the back put 2 jackstands.. Then I can proceed to rotate the tires or bleed the brakes?
I know people jack from the side but not sure if I want to do this, once you damage the rail on the side you have a hard time using the spare jack.
